![]() | Home > Maintenance & Mods (L322) > Rear lower wishbone help |
deltic Member Since: 18 Jun 2018 Location: dublin Posts: 57 ![]() ![]() ![]() |
Sorry its al322 2005 rear bushes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
have you looked in the wiki????? |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1545 ![]() ![]() |
Inner or outer?
Its the inner ones thanks |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
You could probably get the wishbone off without deflating but you will NEVER get it back on! PLEASE do not try this!
Thanks for that JOE 90. Could you tell me where the rear release valve is located i have started on the left passenger side and thanks again |
Unfortunately, given you have started on the passenger side, it is behind the Rear Right inner wing.
I think i have made a balls of this i reversed it up on ramps and took out the two w/ bone bolts out and the suspension is in standard mode i may have to put them back in and start again thanks |
Suggest, before you go any further, get yourself a copy of RAVE from the wiki !!
Thanks JOE90 i am going to start again what is the best position for suspension to be at i am going to take it off the ramps on level ground it will be safer will i be able to get lower w/bone off before lowering the a/bag i have only to replace one bush there on each side and the 2 rear sub frame ones also what amount of hours will this job take thanks again. |
Normal height is a good setting.
Made a bit o progress got car on stands lowered left rear air bag released 2 inner bush bolts lowered inner side of w/bone down can the bush be extracted without taking the w/bone out every nut and bolt on these machines seem to be welded thanks again JOE90 |
Well got a bit done car on stands left rear a/bag deflated inner w/bone bolts out that drop link nut took an hour am going to have a go at bushes on the car every nut and bolt on this machine is welded with rust. thanks all |
Got stuck in to this job decided to take Joe 90s advice took upper wishbones out bushes were tough to get out only managed 1 but had no play in them the 2 that it was failed on were perfect, bought the set and sending them out to get pressed. I got the same pressing kit as JOE 90 and broke on of the shafts in two , painted the w bones a very time consuming job so i have to press on cheers |
