![]() | Home > General (L405) > How reliable are current model RRs? |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Andy S and MJGH:
Mca71 Member Since: 25 Sep 2018 Location: Uk Posts: 33 ![]() |
Hi, new to the forum as I am actively considering 405. I have driven BMWs for the last fifteen years or so, an X5 and currently a 5 series. I would like to go back to an SUV and like the look of the RR.... however... having started to research a bit it looks like there are lots of issues with the diesels... I need a euro6 compliant engine, but concerned about all the oil filter, crankshaft, issues talked about and servicing all the time. I am considering a 1 year old vogue set with the 3l diesel. I typically drive a few miles to work, with occasional 100 mike drives once or twice a month.
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1245 ![]() ![]() |
MCA
I’ve had an absolutely disastrous month and a half with mine and LR have been a complete pain the the a125e, so much so that I’ve been looking at the alternatives over the last week - even an XC90 |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
Glad to hear you are finally getting a semi suitable loaner |
Thanks, yes - I’ve made sure it has and you’re absolutely right - in that order! |
Cobstar Member Since: 26 Aug 2010 Location: Hampshire Posts: 38 ![]() ![]() |
@Red Merle - glad you're picking up the D5 loaner tomorrow. Looking forward to in depth RM reports on the drive, useability and towing ability. Just don't think I'm ever going to love the D5. Although the red one in the ads looks quite handsome side-on.
AndyS Member Since: 27 Feb 2016 Location: Lymington, Hampshire Posts: 408 ![]() ![]() |
I saw a black D5 yesterday at our son's school and the rear panel with the number plate had been centralised into a normal position and it improved the looks a lot from the rear. I image it was an aftermarket part, still not a looker though. |
I’ve only seen photographs of those so far, not it real life. It’s about £1,200.00 to get that repair kit supplied and fitted. It’s interesting to read the -ve reaction to the repair on the D5 forum; apparently it spoils the “purity” |
Thanks for the info so far.... do the v8 diedel engines suffer from the oil dilution problem in the same way as the v6? |
@ Cobstar: Thank you!
stillrunning Member Since: 10 Jan 2017 Location: Cheshire Posts: 268 ![]() ![]() ![]() |
RM,
Been doing my research and it seems that he tdv6 is the problem engine and the sdv8 is not affected by the oil dilution issue... a lot of unhappy tdv6 owners out there... it’s enough to put me off buying the approved used that I was actively considering which otherwise was perfect colour/spec for me What I’m not clear of is whether the sdv6 engine is not affected. Looks like I will now need to hold out for either a1-2 year old sdv8 in my spec, or wait until next year until the sdv6 start coming through the approved used market. Ho hum. |
