Home > Technical (L322) > only cold air from centre vents |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Hi all anyone any idea why I am only getting cold air from the centre vents? |
23rd Sep 2018 4:14pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
try turning the knurled knob to red...
23rd Sep 2018 4:16pm |
Tried that Stan it doesn't matter what setting its on it is always cold guess there is a flap motor gone or maybe a sensor |
23rd Sep 2018 4:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
This is something I too was about to investigate, missing the blast of warm air on my cold hands in the morning once the 'stat opened up (wot I used to get in the '02 TD6). Don't seem to be getting much of anything out of the side vents either (although the little demist vents are kicking out warm air). This is with system set on auto with dot light and smile light on on the button, and AC on. .
23rd Sep 2018 4:48pm |
Very similar indeed |
23rd Sep 2018 4:54pm |
looks like theres a flap that goes faulty,
23rd Sep 2018 8:01pm |
A bit more testing this morning, in auto mode with centre wheel on full red, I get a trickle of warm air, with drivers setting on 22. If I turn drivers setting up to 28 I get no hot air ? .
25th Sep 2018 10:38am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
Final stage resistor defective? Only Range Rovers since 1988 |
25th Sep 2018 11:51am |
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 |
Does sound like the hedgehog has given up the ghost (a common problem). Replaced mine 12 months back & it's been fine since then.....and my knuckles have healed & the double joints in my wrists re-aligned lol Current RR L322 TDV8 VOGUE
27th Sep 2018 10:03am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3136 |
I had this on my 2004 V8 petrol. Even CTC count fix it. It's to do with the coolant pipe/switch providing hot water for the air interchange. try removing the big pollen filter under the windscreen and re-seating/re-fitting.
27th Sep 2018 12:36pm |
Replaced the hedgehog on mine about a year ago and fan speeds are all ok will try and get into it this weekend and test the flaps |
27th Sep 2018 8:16pm |
Will have a go and see what happens |
Update from me
6th Oct 2018 5:48pm |
Funny enough I was having a bit of a play with it on my last trip down to Cardiff and what I have is cold air always coming from the vent which is on top of the dash in the centre so maybe next weekend I will have glove box etc all out and see what is what will keep you posted on the findings |
7th Oct 2018 9:15am |
