![]() | Home > Technical (L322) > L322 Hitachi Suspension Compressor Running |
ChrisJJ Member Since: 31 Aug 2018 Location: Redcar Posts: 39 ![]() ![]() ![]() |
Compressor will run for a few seconds to top up the lines, raise the height or fill the reservoir. Then it should turn off and stay off. Running constantly would suggest you have an issue. Check the airlines are pushed all the way in to the collets. You may need to strip it back down, retrace your steps and double check everything is fitted/seated correctly. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
^^+1
Also, I assume that by seal you mean you've replaced the piston ring?
PaddyZulu Member Since: 29 Mar 2012 Location: Surrey Posts: 16 ![]() ![]() ![]() |
Appreciate the timely replies guys thank you.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
The valves hold the car at height. If the reservoir is not getting up to pressure, you should see problems moving from normal height to off road, back to normal to access height and then back to normal. Do this with the engine running. Also a diagnostic tool will be able to show you the reservoir pressure should be above 180 psi. .
leak in reservoir wouldn't cause a loss in height due to one way valve in block.
OK guys thanks for that gives me something to look for. I'll be back when I've had time to check out the suggestions. |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
After doing the repair did you change the relay which is mandatory when changing the compressor?
Hi all,
