Home > In Car Electronics (L405) > Fitting Dash Cam |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
With information from Alistair in this thread http://www.fullfatrr.com/forum/topic30917.html
16th Sep 2018 6:19pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
I wired ours into the rear fuse box - really easy, nothing to unscrew. Straight across the headlining on the right hand side and then down the C pillar into the fuse box. |
2nd Dec 2018 10:26am |
One of the reasons I ran my wire down to the fuse box was because I didn't want to tap into a wire up there and I wouldn't have known which wire to use. However, running it down to the fusebox took an extra 10 minutes and that was the way I had done it on my previous D4's Cheers Ian
2nd Dec 2018 11:42am |
Nooney787 Member Since: 17 Dec 2018 Location: Lincoln Posts: 26 |
Great ‘how to’ Hairy Dan! One question though; how does the A pillar trim actually come off? I’ve removed the ‘airbag’ tag, taken out the bolt and the door seal but this only succeeds loosening the trim a bit - are there any clips or a particular direction to pull in? I don’t want to break anything (or set the airbag off!!). |
19th Apr 2019 8:40pm |
I seem to remember once the screw is out and the door seal pulled away I pulled the top out first and levered it down as there is part of the lower that slots down between the screen and the dash. As far as I can remember there aren't any other fastenings or clips apart from the screw Cheers Ian
19th Apr 2019 9:02pm |
fin Member Since: 20 Oct 2010 Location: South East London Posts: 51 |
One thing to consider if someone is using this as a guide, is if your unit has GPS for speed cameras etc. Before you pick the final place and stick it in (with the worlds most stickiest 3m tape) trial it in a few places as I found (the hard way) that when I took my unit out the L322 and put into the L405 the screen/car is much more difficult to get a decent GPS signal |
21st Apr 2019 2:45pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
Just found this.
22nd Feb 2020 12:17pm |
millerj90 Member Since: 25 Oct 2010 Location: Melksham Posts: 335 |
@Fin
19th Jun 2020 2:41pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35434 |
have you moved the FF to a different location or even turned it round on the drive... ... - .- -.
19th Jun 2020 2:59pm |
@Stan - I spent most of the afternoon trying different positions on the windscreen. I managed to grab a signal once, but couldn’t reproduce it. Didn’t think about turning the vehicle around, great idea, think I’ll go and try that now. |
19th Jun 2020 3:42pm |
Not a Harley Rider Member Since: 28 May 2020 Location: England Posts: 9 |
Brilliant how-to, thank you just hard wired mine. I had the same issue as "Nooney" in that the A pillar trim refused to budge (I have been known to be too cack handed so I backed off) a curved wire coat hangar enabled me to feed the cable up into the A pillar. I have the NextBase camera & found this kit on Amazon, although it arrived with a full size add-a-fuse (I had already ordered a mini add-a-fuse. https://www.amazon.co.uk/gp/product/B07L59...&psc=1 |
23rd Jun 2020 11:55am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Won't the heat reflective windscreen prevent the GPS from getting a signal..?? Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
23rd Jun 2020 12:39pm |
@Haylands - Pete, that is the problem I’m trying to prevent. I positioned the camera in the same place as I had it in my L322, which had the heated screen and sun reflective coating (as far as I know) and it was fine. I’m not sure if this L405 has a thicker coating, but I am indeed suffering with a loss of GPS signal.
23rd Jun 2020 4:53pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7964 |
Mines here & seems to work OK - telepeage tag one side, dash cam on the other.
23rd Jun 2020 5:01pm |
