![]() | Home > Maintenance & Mods (L322) > Tail gate window seal |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Cheezels
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
That's odd. Pretty sure I uploaded the photo.....
Ahh, now I see that my 11MY does not appear to have this strip fitted. My bad!!
I seem to remember reading on here somewhere that that trim can be removed without needing to replace it. It's cosmetic only not a seal as such. The problem is however the quality of the paint finish under it if you do remove it. I have a suspicion that you may have to do some work on the paint if not repaint. |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
This slides out sideways if you carefully persuade it from one end. |
Thanks for that.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8686 ![]() ![]() ![]() |
Tbh, if you take it out and the paintwork will clean up I wouldn’t bother putting it back. It’s decorative only and wasn’t on the facelift 07->
gonfishen Member Since: 18 Jul 2016 Location: melbourne Posts: 11 ![]() ![]() |
Easy to fit the new one, i just pushed it in from one end liberally coat it with silicone spray and also spray the edge of the window and top of the tail gate. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Mine bottom piece was never fitted when the upper tailgate was replaced and one of the side strips fell off so I took the other one off to match.
Hi Mike
