Home > Maintenance & Mods (L322) > Tail gate window seal
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Just wondering if anyone would know if the outer seal could be replaced without removing the window?
I'm not sure if this damaged bit is separate to the actual "body to window" seal?
Anyone have experience with this issue??
Cheers 2007 3.6 TDV8
Post #487414 29th Aug 2018 8:03am
rjff
Cheezels
Mine is a 2011MY but I would think you refer to the strips down the outer edges of the glass, which I believe were originally some form of metal. They corrode and look poor. When I purchased mine the dealer replaced those strips with a rubber or silicone strip moulded to fit. Can't assist on supply of these, but looking at the tailgate just now the replacement should just slide on after removal of the original and the dealer did not mention removing the glass..
Edit
Try searching on Microcat, links in Wiki. These links may help
https://allbrit.de/epc.cfm?PAGE=5011125A&a...SPRACHE=EN
Hope this helps
Richard
Post #487415 29th Aug 2018 8:36am
cheezels
That's odd. Pretty sure I uploaded the photo.....
Try again, I shall
 2007 3.6 TDV8
Post #487421 29th Aug 2018 9:08am
rjff
Ahh, now I see that my 11MY does not appear to have this strip fitted. My bad!!
Perhaps a main or indy dealer or screen fitter could help if not forthcoming from members here.
Richard
Post #487464 29th Aug 2018 5:19pm
I seem to remember reading on here somewhere that that trim can be removed without needing to replace it. It's cosmetic only not a seal as such. The problem is however the quality of the paint finish under it if you do remove it. I have a suspicion that you may have to do some work on the paint if not repaint.
Post #487466 29th Aug 2018 5:41pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
This slides out sideways if you carefully persuade it from one end.
Post #487473 29th Aug 2018 6:27pm
cheezels
Thanks for that.
I'll ask Dan for a new one 2007 3.6 TDV8
Post #487547 30th Aug 2018 10:41am
Tbh, if you take it out and the paintwork will clean up I wouldn’t bother putting it back. It’s decorative only and wasn’t on the facelift 07->
Neither my 08my or 12my had one. There is nothing that can't be fixed with a hammer😜😜
Post #487548 30th Aug 2018 11:08am
gonfishen
Australia
Easy to fit the new one, i just pushed it in from one end liberally coat it with silicone spray and also spray the edge of the window and top of the tail gate.
Post #488487 9th Sep 2018 11:26am
Baltic Blue
Mine bottom piece was never fitted when the upper tailgate was replaced and one of the side strips fell off so I took the other one off to match.
Post #488489 9th Sep 2018 12:03pm
cheezels
Hi Mike
Did you have a part number for the seal?
Post #488490 9th Sep 2018 12:33pm
