Home > Technical (L322) > Is EGR blanking needed after delte?
paulgo
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Just had the EGR valves on myTDv8 mapped out with an extra 45bhp added too, which is very nice power-wise, (wow she flies!!) although not see quite the increase in mpg I was hoping for (which apparently is helped by the bhp increase).
I was told that if the valves are working ok and are able to shut properly there’s no need to blank them off necessarily, as they are now essentially turned off. I’m wondering if it’s still worth blanking them anyway as the kit is quite cheap and it looks like a job I can do myself, once I figure out exactly where they are!
So for those who have had the remap and delete – did you blank too?. 2007 Range Rover Vogue 3.6 TDV8
Post #487983 4th Sep 2018 2:26pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Yes.
The kit was approx. £35 on the Bay of Fleas and straightforward - if fiddly to fit.
https://www.ebay.co.uk/itm/RANGE-ROVER-Vog...238a30b334
You WILL need a magnetic pick-up device to avoid dropping bit into the turbo.
Instructions that cam with kit are quite comprehensive and easy to follow - similar to swapping the EGRs for the most part, but with much less stripping down.
Post #487991 4th Sep 2018 5:11pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I didnt on my 2007 BUT for that price has to be worth it. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487995 4th Sep 2018 5:20pm
I’m considering doing this via the IIDTool patch but was put off by having to do the dirty bits as well. Got - 2017 SDV8 Autobiography in Loire Blue
Post #488001 4th Sep 2018 5:55pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Can an egr delete be done to an existing map or does it have to be remapped again after egr delete or can Eml light just be turned off with a tool
? _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #488053 5th Sep 2018 10:26am
berkshirelad
You can reset the EGR fault with an IID and this will turn off the EML light.
It will turn back on as soon as the EGR fault re-occurs.
The EML light can be lit due to several causes not just EGR. An IID will tell you exactly what.
Mapping out the EGRs is the re-map (ie remapped from standard). I simply had the intermediate power re-map done at the same time as the cost is the same.
Post #488059 5th Sep 2018 10:55am
Can I ask who did your remap and EGR for the same price? Got - 2017 SDV8 Autobiography in Loire Blue
Post #488061 5th Sep 2018 11:02am
paulgo
I paid £300 for the remap and delete. Company I was recommnened to in Teesside called Monster Tuning 2007 Range Rover Vogue 3.6 TDV8
Post #488150 6th Sep 2018 3:30pm
berkshirelad
A company called Southern Re-Mapping near Chieveley in Berkshire.
As I recall it was £375 for the mid-power re-map and the EGR delete was a free add-on. If I had wanted just the EGR delete, it would still have been £375 and left with standard map and EGR delete.
Post #488152 6th Sep 2018 3:56pm
SteveRRL322
I've had a remap and egr delete with plates fitted for £350 all in. Made a big difference.
Plates are there for piece of mind as the end of the egr could still fail and fall off. With the plates there
If they did it wouldn't matter as the plates protect the intake.
Steve.
Post #488160 6th Sep 2018 6:01pm
My predicament is that I already have a remap and doing the EGR mapping will also delete my remap. If I put my old remap back on, it will delete the EGR mapping, so I’m effectively paying for a remap I already have, to allow for both. Got - 2017 SDV8 Autobiography in Loire Blue
Post #488173 6th Sep 2018 7:58pm
SteveRRL322
No I don’t think it works that way Alan, when the guy remapped mine he downloaded all my current map
And edited the values for quite a few settings. Injector opening , boost, fuel rail pressure. The egr is part of those
Values which you just edit to zero so it doesn’t open anymore. So anyone who edits your current map should be able
To zero out the egr settings without touching your current map. The plates where then fitted on the pipe
That comes out of the egr that goes into the induction so no damage can occur if the egrs do break up.
That’s what I saw anyway.
Post #488187 6th Sep 2018 8:45pm
My situation is a little different Steve. I currently have a Bkuefin remap and having spoken the guys at Bell, they confirmed that the EGR delete map via the IIDTool will overwrite any previous map installed.
The EGR only map is around £250 but to have the power boost and EGR delete is over £400, nearer £500, so my choice is, keep my remap wihich is bought and paid for, or pay for the IIDTool remap nd EGR together. Got - 2017 SDV8 Autobiography in Loire Blue
Post #488196 6th Sep 2018 9:09pm
SteveRRL322
Seeing as the Bluefin just over writes any current map I can’t see a problem if you can find someone who can edit the Bluefin map on the car. Pete is an expert but there are other people who can do it. Where do u live?
Post #488200 6th Sep 2018 9:26pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I had two quotes for EGR delete and both offered a remap included in the price. Both were similar at around £250. One was with a Quantum agent cvd the other with a well respected independent.
So if you want to retain a remap and get an EGR delete you ought to be able to do it for around that price. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #488205 6th Sep 2018 10:14pm
