Home > Maintenance & Mods (L322) > 4.4 TDV8 Exhaust Smoke/Drain Mod Issue
Has your 4.4 TDV8 experienced the exhaust smoke issue and had the sump/drain mod?
Yes
35%
 35%  [11]
No
64%
 64%  [20]
Total Votes: 31
Has your 4.4 TDV8 experienced the exhaust smoke issue and had or needs he sump/drain mod? VOTE ABOVE Thumbs Up
Note: as those effected more likely to vote please ensure you vote if your car has had no such issue. Thanks.
Last edited by Gazellio @ Prestige Cars on 30th Aug 2018 8:00am. Edited 2 times in total
Post #487472 29th Aug 2018 6:15pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Not the best of questions really, mine does have a smoke problem and hasnt had the mod done (yet). BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #487479 29th Aug 2018 7:04pm
You cannot edit poll wording but I have edited the post. I am sure you get the gist answer yes as you have the problem.
Post #487481 29th Aug 2018 7:09pm
mjdronfield
Not had the mod. Had a smoke issue but cured by going over 2500 rpm at least once each drive.
So not planning on the mod. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #487486 29th Aug 2018 8:32pm
GraemeS
Mine had the mod done preemptively when purchased s/h so I don't know if it smoked before but it does not smoke now. I can't decide if that's a yes or no vote.
Post #487488 29th Aug 2018 8:39pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
My car has not been modded, and doesn't smoke.
It gets revved above 2k regularly, and above 2k5 a couple of times on my commute. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #487490 29th Aug 2018 8:57pm
YES vote if its had the mod or smoke
Post #487497 29th Aug 2018 10:24pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
mine didnt smoke as the DPF caught it all but it needed the drain mod as it was using oil.
if i stayed around 2k rpm or less it didnt use oil, if i pushed on a bit it would. drain mod fixed it.
problem also caused dpf to fill quickly, not helped by leak between the two dpf sensors so it had even more soot in it than it thought. had leak fixed and drain mod done
took quite a few long dpf burn off conditions to reduce the soot grams (hawkeye reading) in the dpf but its recovered and has been ok for last 12mths on it. (touching wood) Cheers
James
Post #487504 30th Aug 2018 6:14am
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
I have voted "yes", mine has been in and out of the garage for about 2 years, it has had the mod, the drain, pipes replaced, oil cooler replaced and some gasket thing. The smoke appears to have reduced considerably but the smell is still there especially if you have your foot down. Will let you know when it goes back in shortly. I need more help than most...sorry !!
Post #487506 30th Aug 2018 6:23am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
No mod on mine , no smoke , no oil used and driven gently 90% of the time. It does get a redline blast every so often and a reasonably high speed run as well. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #487507 30th Aug 2018 6:31am
CS
My 2012 WM didn't have the mod, but didn't smoke in the 50,000 miles odd I had it, I think due to hardly any town driving and over 2,500 rpm most journeys. Only Range Rovers since 1988
Post #487553 30th Aug 2018 11:40am
SinbadRose
Same as John W for me. Don't get any smoke, doesn't use any oil from what i can tell (only when leaks start Crying or Very sad ), but it does go up to 2/2.5k every day with good motorway runs at weekends.
Post #487558 30th Aug 2018 12:21pm
rjff
Had ours from October17, no sign of mod. Used in waft mode mostly (no visible smoke) with 2.5k rpm now regular. Smokes initially at that but soon clears.
One yellow DPF in February, cleared in 5 miles at 55mph and one line of oil used on the dipstick in 7K miles to date. Have a recurring restricted performance in the last week AFTER deciding to buy a Gap tool!!
MOT next month Exclamation Cheers
Richard
Gap IIDBT
Post #487570 30th Aug 2018 1:56pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Voted yes as mine's had the mod ... but didn't smoke. What do I put here then?
Post #487573 30th Aug 2018 2:12pm
gg2201
No smoke and no mod living in Cornwall its hilly so it gets revved Laughing 2011 4.4 TDV8 Autobiography
Post #487848 2nd Sep 2018 5:47pm
