Home > Maintenance & Mods (L322) > 4.4 TDV8 Exhaust Smoke/Drain Mod Issue |
Has your 4.4 TDV8 experienced the exhaust smoke issue and had or needs he sump/drain mod? VOTE ABOVE
29th Aug 2018 6:15pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Not the best of questions really, mine does have a smoke problem and hasnt had the mod done (yet). BMW i3 Electric Car
29th Aug 2018 7:04pm |
You cannot edit poll wording but I have edited the post. I am sure you get the gist answer yes as you have the problem. |
29th Aug 2018 7:09pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Not had the mod. Had a smoke issue but cured by going over 2500 rpm at least once each drive.
29th Aug 2018 8:32pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
My car has not been modded, and doesn't smoke.
29th Aug 2018 8:57pm |
YES vote if its had the mod or smoke |
29th Aug 2018 10:24pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
mine didnt smoke as the DPF caught it all but it needed the drain mod as it was using oil.
30th Aug 2018 6:14am |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 90 |
I have voted "yes", mine has been in and out of the garage for about 2 years, it has had the mod, the drain, pipes replaced, oil cooler replaced and some gasket thing. The smoke appears to have reduced considerably but the smell is still there especially if you have your foot down. Will let you know when it goes back in shortly. I need more help than most...sorry !! |
30th Aug 2018 6:23am |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
No mod on mine , no smoke , no oil used and driven gently 90% of the time. It does get a redline blast every so often and a reasonably high speed run as well. 2015 4.4 AB
30th Aug 2018 6:31am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
My 2012 WM didn't have the mod, but didn't smoke in the 50,000 miles odd I had it, I think due to hardly any town driving and over 2,500 rpm most journeys. Only Range Rovers since 1988 |
30th Aug 2018 11:40am |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
Same as John W for me. Don't get any smoke, doesn't use any oil from what i can tell (only when leaks start ), but it does go up to 2/2.5k every day with good motorway runs at weekends. |
30th Aug 2018 12:21pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Had ours from October17, no sign of mod. Used in waft mode mostly (no visible smoke) with 2.5k rpm now regular. Smokes initially at that but soon clears.
30th Aug 2018 1:56pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Voted yes as mine's had the mod ... but didn't smoke. What do I put here then? |
30th Aug 2018 2:12pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
No smoke and no mod living in Cornwall its hilly so it gets revved 2011 4.4 TDV8 Autobiography |
2nd Sep 2018 5:47pm |
