![]() | Home > Technical (L322) > Several Questions |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Tyre pressures are way too high - are you sure your gauge is accurate ?
Northern lad Member Since: 30 Jun 2018 Location: South London Posts: 56 ![]() ![]() |
Thanks Alistair
Sorry just seen your question
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Tyre pressures should be on a sticker in the drivers door jamb.
Not a standard tyre size, but would expect about the same as the L405 on 22’s - this is what mine says -
thanks again Alistair |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1098 ![]() ![]() ![]() |
Cables are for the compressor, the coax looking cable I would guess are the airpipes about 6mm from recollection Current: 2011 FFRR Vogue SE 4.4 TDV8
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 ![]() ![]() ![]() |
How long has your car been sat before you tested them? If they’re hot then the pressure will be higher |
Did you figure out how to use the spare wheel strap - tuck it in the top of the lower tailgate and open |
