Home > Technical (L322) > Several Questions
Northern lad
Several Questions
Morning All
All input appreciated
Firstly I went outside yesterday, and thought the rear passenger side tyre looked a little low, so I thought ide match the pressure with the other wheel, I was staggered Shocked the gauge on my pump read approx. 56 PSI is that correct? checked another that was approx. 62 PSI, couldn't get the dust cap off the valve from front passenger side, I'm used to the 34-36 range, is the pressure that high because she weighs 2.5 tons? anyway whilst on the subject, I knew the spare was flat, so thought I'll pump that up as well (bleeding heavy arnt they Shocked ) the tyre stated 51 PSI max but it looks like its a cheapy make as do all the others by the way.
While it was out of the well, I took the following pictures, is the big black thing the compressor? as does anyone know what the wiring is/belongs to? one of them looks like a standard co-ax connector
 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #487806 2nd Sep 2018 7:33am
Tyre pressures are way too high - are you sure your gauge is accurate ?
What size tyres have you got ?
Yes - big black thing is the compressor for the suspension
Post #487807 2nd Sep 2018 7:48am
Northern lad
Thanks Alistair
I don't know how accurate the gauge is, but its the only thing I have to go by, could you tell me what the Range should be please
Regards
Steve 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #487809 2nd Sep 2018 7:53am
Northern lad
Sorry just seen your question
tyres 285 / 35 on 22" rims 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #487810 2nd Sep 2018 7:57am
GGDR
Tyre pressures should be on a sticker in the drivers door jamb.
I think - pls check though - 35 psi plus or minus is around normal.
. Cheers, Greg
Post #487811 2nd Sep 2018 7:58am
Not a standard tyre size, but would expect about the same as the L405 on 22’s - this is what mine says -
Post #487822 2nd Sep 2018 9:54am
Northern lad
thanks again Alistair Thumbs Up
that is a huge difference from what my pump gauge says, I can only presume the gauge is out (massively) she is not jittery or bouncing around the road or such things, so I think the next opportunity to get to a petrol station and try their air pumps will be quite interesting
I will update when that happens.
any ideas by the way on the cables in the boot? 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #487839 2nd Sep 2018 2:45pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Cables are for the compressor, the coax looking cable I would guess are the airpipes about 6mm from recollection Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #487843 2nd Sep 2018 4:00pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
How long has your car been sat before you tested them? If they’re hot then the pressure will be higher
Post #487860 2nd Sep 2018 9:23pm
Did you figure out how to use the spare wheel strap - tuck it in the top of the lower tailgate and open Thumbs Up .
Post #487863 2nd Sep 2018 10:21pm
