Home > Technical (L322) > missfire issues
Page 2 of 3 <123>
D17 JWB
United Kingdom 2006 Range Rover Vogue SE TDV8 Buckingham Blue
miggit wrote:
Shocked Forgot to add diagnostic tools there are only 2 worth having Genuine Land Rover Test Book (don't ask how much, YOU WILL HAVE A CORONARY!!) or the Gap IID tool which is the be all and end all of home diagnostic tools for the Range Rover... I had the BT IID tool which was fantastic as it didn't rely on my pixelated dash display and used my phone instead!
You sometimes see them for sale on here, just remember that you'll need to purchase a new licence for your VIN, from memory they are £25 ish.... Or do a google for Gap IID !
Just ebay’d gap iidtool £300ish gulp
Censored 2006 L322 3.6 TDV8
Dogs in the back, Kids in the middle, Horses in a box at the rear.
I know which makes more mess.
Post #487785 1st Sep 2018 7:04pm
dingg1
Thats a bargain if its the bt version
Post #487789 1st Sep 2018 9:17pm
D17 JWB
D17 JWB wrote:
Got the first sign of a fault code.
P0501 speed sensor
And the pixel display say
‘transmission Fault traction reduced.’
Hawkeye lists 11 DTCs
P0490
P02B4
P02A0
P02B8
P010C
P010F
P023D
P007F
P0501
U0416
U0002
I have some reading to do..........
Exclamation 2006 L322 3.6 TDV8
Post #487817 2nd Sep 2018 9:12am
miggit
Whistle I wouldn't take too much notice of a generic OBD II reader... they generally tend not to talk Land Rover, and just make it up for fun Shocked
The Gap IID is definitely fluent in Land Rover, and will do a lot more than the others like hawk eye, lynx, etc.
And the cost is only 2 trips to Land Rover for diagnostic work, assuming that they find it in an hour! Yesterday I couldn't spell Engineer... Today I are one!
Post #487930 3rd Sep 2018 10:27pm
miggit
A lot of those fault codes are more than likely caused by a low battery..... As they can't say low battery transfer case and hill decent control faults are the norm... normally fixed with a dam good charging!! Yesterday I couldn't spell Engineer... Today I are one!
Post #487933 3rd Sep 2018 10:34pm
D17 JWB
I took your recommendation it is sitting slumped at Woburn 4x4 as I type Big Cry 2006 L322 3.6 TDV8
Post #488240 7th Sep 2018 8:52am
D17 JWB
I read that a lot in this forum, so the only thing I have done is changed the battery to a Bosch S5 110/920, hoping that was going be the magic cure.................... despite the prayers, ceromony and sacrifice to the Gods the answer was..... NO Censored 2006 L322 3.6 TDV8
Post #488241 7th Sep 2018 8:53am
miggit
Well the new battery will have more than likely put out a few of those fault codes, but it wont cure a fuel fault, which unfortunately you have buddy Big Cry
But on the plus side Woburn 4x4 is probably the best place to get it diagnosed / sorted at sensible prices.... the last thing you'd want to do is put it in the stealers.... that is a last resort option, for a kickoff the stealers wont fit recon injectors only new.... that could be very expensive.
Most sensible places will send them to be cleaned and tested / repaired, but not LR, they only believe in new and all the extra cost that goes with it... and profit Evil or Very Mad
I have spoken to several peeps over the years, who have used Woburn 4x4, and none has had a bad word to say, so positive mental attitude Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #488260 7th Sep 2018 11:48am
holidaychicken
Haven’t read all the detail but is your injector loom ok, it’s a very common fault , if you touch the wiring around the injectors it may cough
Post #488866 14th Sep 2018 6:23am
miggit
D17 JWB Any progress? Yesterday I couldn't spell Engineer... Today I are one!
Post #489007 16th Sep 2018 8:41am
D17 JWB
Thanks holidaychicken, but they can not get it to start. 2006 L322 3.6 TDV8
Post #489442 20th Sep 2018 9:31pm
D17 JWB
Yep Big Cry
One turbo seized, one possible oil seal leak. Censored
No choice but to repair/replace them and then see if it will start. 2006 L322 3.6 TDV8
Post #489443 20th Sep 2018 9:34pm
miggit
Shocked
Embarassed forgot about the turbos... that would explain the squeak...
Whistle might be worth looking into to deleting your EGR valves... would help with future turbo life... Yesterday I couldn't spell Engineer... Today I are one!
Post #489447 21st Sep 2018 7:04am
D17 JWB
Told by W4x4 to not EGR delete the TDV8, fine on all the others but not that engine.
As i was starring into the part filled engine bay of my RR looking at all the crud that the Exhaust gas Recirculation process causes I did want to desperatly stop it. Crying or Very sad
Idea Anyone tried the TDV8 EGR Delete and run successfully for many many miles and had no problems? 2006 L322 3.6 TDV8
Post #489668 23rd Sep 2018 12:17pm
D17 JWB
D17 JWB wrote:
Yep Big Cry
Oil in the air intake Big Cry 2006 L322 3.6 TDV8
Post #489687 23rd Sep 2018 2:40pm
Page 2 of 3 <123>
