![]() | Home > Technical (L322) > missfire issues |
D17 JWB Member Since: 29 Aug 2018 Location: Olney Posts: 32 ![]() ![]() ![]() |
Just ebay’d gap iidtool £300ish gulp ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
Thats a bargain if its the bt version |
Hawkeye lists 11 DTCs P0490 P02B4 P02A0 P02B8 P010C P010F P023D P007F P0501 U0416 U0002 I have some reading to do.......... ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
A lot of those fault codes are more than likely caused by a low battery..... As they can't say low battery transfer case and hill decent control faults are the norm... normally fixed with a dam good charging!! Yesterday I couldn't spell Engineer... Today I are one!
I took your recommendation it is sitting slumped at Woburn 4x4 as I type ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
I read that a lot in this forum, so the only thing I have done is changed the battery to a Bosch S5 110/920, hoping that was going be the magic cure.................... despite the prayers, ceromony and sacrifice to the Gods the answer was..... NO ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Well the new battery will have more than likely put out a few of those fault codes, but it wont cure a fuel fault, which unfortunately you have buddy |
D17 JWB Any progress? Yesterday I couldn't spell Engineer... Today I are one!
Thanks holidaychicken, but they can not get it to start. 2006 L322 3.6 TDV8 Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Yep ![]() One turbo seized, one possible oil seal leak. ![]() No choice but to repair/replace them and then see if it will start. 2006 L322 3.6 TDV8 Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Told by W4x4 to not EGR delete the TDV8, fine on all the others but not that engine. As i was starring into the part filled engine bay of my RR looking at all the crud that the Exhaust gas Recirculation process causes I did want to desperatly stop it. ![]() ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
Oil in the air intake ![]() Dogs in the back, Kids in the middle, Horses in a box at the rear. I know which makes more mess. |
