![]() | Home > Wheels & Tyres > Changing wheels QUICKLY |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
I have the previous “biggest” 1/2” impact gun they done, at 1491Nm. We no longer have air tools in the workshop, air is only used for inflating tyres now...
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
My local tyre guy recons it’s the impact gun that knackers the RR wheel nuts, so always does mine by hand.
I reckon it’s just a |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Ive just sold 20 of these , latest model is a beast , theres a great advert , shows a rally car pulling for a pitstop and one of the crew puts the gun on a wheel nut and instead of undoing the wherl nut it flips the car!!!!! 2015 4.4 AB
That's the one |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35649 ![]() ![]() |
wizzy guns are ok for undoing wheel nuts but you should be careful doing nuts up.....remember to use a low torque setting and to finish of with a torque wrench.. |
Mine gets used for timing belts, stripping dashboards, stripping engines etc. It’s effortless. And if you opt for the M18 range, all batteries are interchangeable ![]() |
I have the Milwakee radio which as well as being indestructible it also charges the batteries. The jacket is also the business in the winter and uses the 1/4 inch gun battery to power the heated jacket |
I had looked at them |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
They seem to have so many models - which one would make my life easier for suspension bolts? Cheers ![]() |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
I’d get the same one I did the High Torque 1/2”, they also do a 3/4” with a bit more Torque but that will easily snap M16 bolts if you are not very careful 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
The new model 1/2" has the same motor ( and subsequently) power of the 3/4" model. 2015 4.4 AB
Stan, the new models from Milwaukee have 4 settings, they link to your phone by Bluetooth and you can change the Torque Settings, speed and trigger sensitivity with the OneKey App for each of the 4 settings - it also lets you track the location of your power tools in case they get nicked, plus a load of other features. They are absolutely brilliant as you can set a dedicated Torque up for several different uses or vehicle wheel nuts. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
