Home > Technical (L322) > 4.4TDV8 Engine Reliability
dhallworth
There was a thread on the Facebook L322 Group earlier about problems with the 4.4 TDV8 engine, I hadn't heard any of it before but was wondering if others had heard any of it?
Quote:
u know very well y they r better a 3.6 lasts longer than a 4.4 they don't snap cranks or spin big ends or put con rods tho the side like the 4.4
Quote:
The 4.4 is know to spin shells and sieze oil coolers fail crank galleries get blocked and they have poor oil circulation at idle. The 3.6 has 3 failings at higher mileage rockers can fail or become porous, the oil lines can block to turbos but better spec oil and flush can sort that and the passenger side turbo has oil line behind heat shield which causes turbo failure due to carbonising.
Another one that caught my eye:
Quote:
I spoke to a very good auto Transmissions specialist they said mega flush is not good as it pumps too quickly and creates a lot of heat and can cause internal seal failure, they do a flush that takes a day for the whole process that doesn’t create the heat, but that was far a sport that requires the the gear box lifting for filter replacement and that’s for the same price as a mega flush
 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #487212 26th Aug 2018 7:32pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Oh dear.
It would be good to put numbers to these claims.
For example, how many of each built, what year and mileage of failed vehicle.
I thought the general consensus was that whilst the 4.4tdv8 has a few issues (leaky o rings, oil cooler gaskets, inlet rubbers, turbo drain mod), there weren't any major failures or huge engine repair bills.
Just how many cases of snapped cranks and spun bearings have there been ? Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #487215 26th Aug 2018 8:01pm
dhallworth
Your thoughts are the same as mine, John.
I always thought the 4.4 was pretty reliable. I'm wondering it one guy has experienced something bad. I know the 3.0 V6's have issues and the 3.6's had issues with turbo's and EGR's but I've heard very little about the 4.4.
Post #487216 26th Aug 2018 8:03pm
Sounds like the poster is confusing the 3.0 with the 4.4..... that’s what happens with those engine. Afaik no such issue is present with the 4.4. There is nothing that can't be fixed with a hammer😜😜
Post #487217 26th Aug 2018 8:19pm
John w
Just did a web search.
I can only find links to a couple of TDV6 and a single 5.0SC failure.
This is hardly indicative of the engines in general, and they arent a 4.4 Laughing Too many toys, not enough time
Post #487219 26th Aug 2018 8:30pm
Baltic Blue
http://www.fullfatrr.com/forum/topic44115.html
My 4.4 tdV8 Fault Log did not find any evidence of engine failures of any kind.
In fact other than annoying failures like rubber inlet hoses and oil cooler rubber gaskets they seem very reliable, especially considering that they are all 7-8 years old and many have covered well over 100k miles.
Only in the last couple of months has one new member started a thread detailing replacing his engine in a car he bought where the engine had already failed.
Maybe he will add to this thread detailing why it failed?
Post #487222 26th Aug 2018 8:52pm
I agree the 4.4 has been confused with the 3.0 that spins the crank bearings! Thumbs Up
Post #487237 26th Aug 2018 11:32pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Interested in the last quote. The oil in these boxes gets pretty hot pretty quick. Unless the mega flush boils the bloody stuff I cannot see how it could damage a box?
I've had all of mine hot flushed, not mega flushed with great results and nil problems. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #487239 27th Aug 2018 12:57am
cass
But it’s on Facebook so it must be true
Post #487240 27th Aug 2018 1:02am
Dijit
I must confess to astonishment at the 3L spinning shells. Anyone know if they don't have securing lugs so they are locked when the main & big end cap are torqued down? Blimey, I'm old enough to have scraped white metal off the conrods before separate shell bearings were introduced. There must be an oil issue to heat them up enough to spin? Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #487241 27th Aug 2018 1:07am
No locking tabs. There is nothing that can't be fixed with a hammer😜😜
Post #487243 27th Aug 2018 7:41am
somebody mentioned this before on the forum, and I'm sure it was facebook info or from a very knowledgeable mechanic Rolling Eyes
Post #487244 27th Aug 2018 8:06am
Baltic Blue
Looks like this member has a tale to tell.....
http://www.fullfatrr.com/forum/topic48437.html G reg 2.5VM Vogue Portofino red 1991- 1999
Post #487246 27th Aug 2018 8:51am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
There’s nothing that seems to energise Land Rover forums more than a potential bad news story about engine reliability Rolling Eyes Laughing
Post #487248 27th Aug 2018 9:13am
pld118
It doesn't seem to me there is a major engine reliability problem with any of the ffrr variants. Certainly, not based upon the low number examples doing the rounds on this forum. On that basis, there doesn't seem to be too much in it between any of the engine variants.
Also, this thread has been posted on the L322 section about the L322 4.4 and it's straying into the L405 3.0 v 4.4 debate?
That might confuse 'the uninitiated' Embarassed
For the record, our L405 3.0 is very reliable and causes me no concern at all. They're all reliable... until they become unreliable Mr. Green
Post #487250 27th Aug 2018 9:45am
