Home > Technical (L322) > Front suspension
A.Pires
Portugal 2002 Range Rover Vogue Td6 Zambezi Silver
Front suspension
Some weeks ago, I've replaced all the suspension control arms due to bad bushes. It where much easier to replace the complete arms than the bushes. I've tightened with the specified torque.
Now the front suspension is a bit lower than the specified on RAVE.
Workshop manual specifies front measure from the hub center to the wheel arch 493 +-2mm. Mine is with 470+-.
There is a special way to tighten the control arms or must I raise a bit the front to achieve the correct measure and then tighten?
Cheers
Post #487067 24th Aug 2018 10:21pm
Believe they should be torqued when wheel is on the ground or when suspension is aligned with the road going position.
What was your suspension height before you changed the control arms ? .
Post #487071 24th Aug 2018 11:23pm
A.Pires
Front suspension
Hi Joe
Don't know. I didn't measure. It was the first time that I have replace control arms in a car.
I own LR's for 30 years. The last time that I've changed something in a suspension, was on my Disco 200 Tdi the radius arms bushes. On my Disco TD5 only the rear air bags.
After all this, now I have a knocking on the right side. When on a bumpy road it sounds. I suppose that is the hub bearing. I have read also that can be the suspension strut which inner buches and shims gone off.
Do you know the size of the socket to remove the hub nut or that is a special tool? That nut is a strange one just looking at,
Cheers
Post #487157 25th Aug 2018 10:27pm
HERE is a thread all about it Thumbs Up .
Post #487158 25th Aug 2018 10:43pm
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I have just replaced every joint and bush on the front of mine you need to slacken the main bush bolts off lower the car so the weight is on the front wheels then tighten the bush bolts.
Post #487160 26th Aug 2018 12:34am
holidaychicken
I drive up on to a couple of railway sleepers to give me the height required as some of the bolts are pretty tight and need a decent length of torque wrench
Post #487162 26th Aug 2018 12:51am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Re: Front suspension
A.Pires wrote:
Hi Joe
Cheers
36mm 12pt for socket
Post #487266 27th Aug 2018 12:33pm
