Home > Technical (L322) > Gearbox thud when selecting Drive or Reverse. 2003 4.4V8 |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1249 |
Bit of history.
25th Aug 2018 3:27pm |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Bumping this as I have the thump when selecting gear on a slope .. very interested in a resolve |
29th Aug 2018 12:09pm |
I’ve just been informed it’s the transfer box chain that stretches causing this to thump |
29th Aug 2018 4:16pm |
Thanks for the info. I guess that could well be the issue as its probably never been looked at. Don't suppose you have any idea of what the seriousness / consequences could be, or if its OK to live with it...
29th Aug 2018 4:22pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Guy's, That may cause the slight thump. But I can't see that this would cause any issues with engaging gears on a slope?.
29th Aug 2018 5:04pm |
In our case we get the thump when on the flat, might be a bit of a red herring with the sloping drive! The way the lane is we have to drive past the house, reverse back at 90 degrees then drive forward across the lane to straighten up, then onto the sloped drive, its at this point we get the thump, so sequence is in drive, then reverse, then drive and reverse again. Trans fluid has been checked and TC was replaced with new when gearbox was rebuilt and we don't get the fluttering rev counter needle |
29th Aug 2018 5:11pm |
I can see why the chain could be an issue with yours due to the amount of maneuvering required. I do get a slight thump / clunk when selecting low ratio, so I assume that I also have some play in the transfer box chain.
29th Aug 2018 6:45pm |
Going to get the transfer box oil level checked out. My wife drives the car more than I do and its only used for short journeys really, when I drive it I tend to find somewhere quiet and drop it into low ratio for a short time and if on any longer drives will use sport mode to give the box a bit of exercise! |
29th Aug 2018 6:54pm |
I was speaking to my mech earlier and it was him and another chap who mentioned the chain.. my transfer box fluid is changed every year on mine so rules out that.. he says it’s nothing to worry about .. mines is perfect on the flat but the slightest of incline and it will do it.. |
29th Aug 2018 7:14pm |
Just had the clunk with difficulty in engaging gears on a slope. I'm assuming that this is just the slack in the chain being taken up or am I into something more . |
2nd Sep 2018 5:20pm |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
Anyone manage to resolve this?? |
1st Feb 2019 7:28am |
Markwood71 Member Since: 19 Sep 2019 Location: Dudley Posts: 31 |
I get a CLUNK when i first engage D from P in the morning. After that it seems fine. Have been told its because i am parked on a slight slope and its normal to have a clunk. Anyone else get this> ? |
26th Nov 2019 11:07am |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Post #53550226th Nov 2019 11:07am
26th Nov 2019 2:24pm |
