Home > Maintenance & Mods (L322) > Converting twin towing plugs to single
Andy
Hi guys
I need to convert my twin electrics to a single 13 pin plug. Has anyone done this and what’s it like to do?
I have the new plug ready to go on
Thanks
Post #487110 25th Aug 2018 1:52pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I did it on our old RR (which just had a single 7 pin) and had to buy the complete kit including new electrics box that goes in the boot.
As you already have the twin sockets, I don't know if you'd need to change the electrics box or whether you can just wire up the plug, sorry.
Our current one has two 7 pin sockets and we just use a converter cable that works perfectly:
https://www.amazon.co.uk/Socket-Caravan-Mo...ng+adaptor
As we just use an adaptor, which is exactly the same as just wiring up a 13 pin socket, I think you're probably going to be OK if you can get the wiring diagrams.
Post #487114 25th Aug 2018 3:31pm
Re: Converting twin towing plugs to single
If you have to ask, then it might be tough..... and if you get it wrong, it’s an MOT failure.
I assume you mean you have a socket ?
The individual cables are colour coded and there are plenty 0f wiring diagrams on the net - but it’s pretty fiddly to do.
It might be easier just to buy an adapter
Post #487116 25th Aug 2018 3:38pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Ive just done it, Im just making up the details etc into a document, I'll upload it later.
My wiring had been on fire!! (before I owned the car). BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #487117 25th Aug 2018 4:05pm
Weegie
P.F. Jones sell appropriate adapters:
https://www.pfjones.co.uk/towbar-electrics-guide.html John
GAP iiD BT-Sold
Post #487144 25th Aug 2018 7:32pm
AJGalaxy2012
These are the connections I traced out, dead simple job to wire.
 BMW i3 Electric Car
Post #487148 25th Aug 2018 8:47pm
Andy
That’s great. Thanks
Post #487206 26th Aug 2018 6:31pm
AJGalaxy2012
Because the wiring just behind the 12s plug had been on fire on mine I used a short piece of 12 core cable and then spliced it onto the plug, All worked out well in the end. BMW i3 Electric Car
Post #487214 26th Aug 2018 7:37pm
Andy
It appears the missing wire in my loom is the blue/pink that goes to pin 9. I don’t have that one.
Post #491445 8th Oct 2018 5:20pm
AJGalaxy2012
The plug in the nearside boot looks like this, kthe constant live is here
 BMW i3 Electric Car
Post #491449 8th Oct 2018 5:58pm
Andy
That’s a different plug to mine. Mine has BMW electrics.
Post #491451 8th Oct 2018 6:02pm
AJGalaxy2012
Ah I didnt realise. BMW i3 Electric Car
Post #491453 8th Oct 2018 6:18pm
Andy
Sorted. All working as it should. Thanks for all the help
Post #491601 9th Oct 2018 5:33pm
