Home > In Car Electronics (L322) > Rear View Camera Replacement Advice
Videoman1959
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Hi Everybody! I have a L322, 2007 Vogue HSE.
I tried to sort my rear view camera today, alas, as usual, no good came of it! So here a few pics of what I have and a brief description.
I do have power coming to the unit via the red/yellow and brown cable through the top of the rear window/door. I presume the silver-end connector is the lead that connects back to the tv.
As you can see, the connections FROM the camera are red/black and the gold tv connector.
Both the red/black and the tv cable fed into the camera through ONE black cable and this actually went straight into the back of the camera lens itself.
There wasn't any other wires in the camera box as you can see from the photo. ( just a load of black solid silicon )
I would like to fit another camera- ANY camera that works would be fine but the ones on ebay etc that I have seen come with audio phono type jacks so I am at a bit of a loss as to what kind to buy so that I can virtually 'plug in and play' with it. I dont mind a bit of drilling and fixing, but need to know about the connections really.
Thank you for your time. 'Knowledge Is Power'
Post #487025 24th Aug 2018 5:28pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
watching with interest as I want to go down this road as well
Post #487051 24th Aug 2018 8:34pm
have you looked in the wiki?
Post #487053 24th Aug 2018 8:45pm
Videoman1959
Wiki
Yes, thank you Stan, I have ( But didnt know that it existed until you asked about it !) but the two posts dont really explain the wiring question. I think that I will pop into Halfords today and see what they say about connecting a new camera up to the existing cables. I dont really know what each of the cables do.... that would help I suppose! :-/
Cheers 'Knowledge Is Power'
Post #487082 25th Aug 2018 7:23am
Videoman1959
I have found this link Dave which might help you..
http://www.fullfatrr.com/forum/topic38680....onnections 'Knowledge Is Power'
Post #487104 25th Aug 2018 12:48pm
dingg1
considering that the camera fitted is an aftermarket ebay jobbie
to save yourself too much trouble and assuming the camera is the issue and not the connections to the vehicle electrics
I'd buy another ebay camera , cut the camera off with a few inches of cable free , inside is two wires one black and one red .
pull some cable from the fitted camera chop and solder , black to black red to red , fixed without too much chew.
did exactly the same to mine and its worked well ever since Thumbs Up
Post #487106 25th Aug 2018 1:18pm
Videoman1959
Thank you Dingg. So I buy a new cheap camera from eBay and then I just reconnect the current gold-ended cable from the old camera cable to the in-place silver connection, and then snip, strip back and join the new camera cable to the old red/black cable that is already in place and reconnect that to the white connector?
Is that ok?
Cheers
**UPDATE**
https://www.ebay.co.uk/itm/Car-Rear-View-R...Swz2lXDLyB
I presume that as this camera (linked above ) has a red/black cable, this should be connected to my black/red connector AND being as a video lead also comes with the camera, I presume that that goes straight into the old silver tv connector?
Post #487118 25th Aug 2018 4:05pm
dingg1
no
to save feeding all the cable through all I would do is pull any slack from your in place camera lens , snip that wire , inside there is two wires one red one black , take your new ebay camera snip that lens with a tail of 4 or 5 inches , rejoin corresponding red and black wires , heatshrink or tape up and push back into upper rear tail gate , all this saves you removing the upper tailgate and hassle of getting the plugs through the access holes
as long as your issue is the camera lens itself it works , if the issue is in the associated cabling (doubtful IME) you'll have to dismantle reduce thickness of connector plugs and feed through access hole etc , its a bit more time consuming to do.
I've went through a couple of the ebay jobs when water ingress ruins the picture I just do as I suggested , takes much less time
Post #487125 25th Aug 2018 5:09pm
Videoman1959
... thank you again Dingg I do understand........ and the Video cable that comes with new camera goes into my current silver connector then? If not, what goes into the silver connector ?
Post #487133 25th Aug 2018 5:47pm
dingg1
https://www.ebay.co.uk/itm/E6A7-C1DA-HD-17...Sw5sBbgYkG
buy that ^^
cut off the camera with a 5" tail
pull through cable on your existing camera , cut back
connect black to black and red to red
job done
leave your connections as they are , the power neg and pos in the white connectors and the brass to metal connection hooked up together
hth
Post #487135 25th Aug 2018 6:01pm
Videoman1959
Cheers ! Very Happy Very Happy 'Knowledge Is Power'
Post #487141 25th Aug 2018 6:43pm
Videoman1959
Tomorrow
Hi Everybody, weather permitting I will try and assemble the new camera that came last week. I will follow Dingg's instructions and see what happens! 'He who dares.... wins!' 'Knowledge Is Power'
Post #488608 10th Sep 2018 6:33pm
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Good luck Videoman. I shall be following with interest.
Post #488623 10th Sep 2018 9:35pm
Videoman1959
Camera Job
Well Dingg, I must admit that your electrical know-how worked just fine, Thank you! Smile
Once I cut and re-connected the cables, (they were VERY thin, but they were correctly coloured) I had a a picture on my screen! Yeahhhh!!
However, as usual with me, I couldn't follow instructions and went a little off-piste. I was too impatient and couldn't wait for Dingg's suggested camera to arrive.... but to cut a long story short, I ordered a different camera and it didn't fit nicely into the camera casing.... consequently, I had to mackle-it! .......and then when installed it didn't focus on the ground, but on my bedroom window!..... and after another go at redirecting it.. .. it doesn't work !
So, moral of this story. ''Do as you are told by someone of superior knowledge''!!!
But at least I know it WAS a fault on the original camera and I need a new one, again......
Thank you Dingg and everyone else Smile 'Knowledge Is Power'
Post #488800 13th Sep 2018 7:19am
