Home > Technical (L322) > Trans fail safe mode
Wickford90
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Barolo Black
04, 4.4 v8 petrol.
After a few minutes it goes into trans fail safe mode, I have recently had gearbox oil and filter changed to cure rumble.
Reading some previous posts people mention cooling issues, mine does lose water. Would a diagnostic say what the issue is or just give a list of possibles. Should I get a new rad and take it from there.
Thanks.
Post #486119 14th Aug 2018 9:21pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
Is your transfer box working correctly? That’s how my issues started on my last car.
Try shifting from high to low and back two or three times. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #486134 15th Aug 2018 7:30am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Do you get any other issues at the same time like suspension inactive?
Cheers ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #486139 15th Aug 2018 8:31am
RRPhil
When you’re in failsafe mode, does Reverse still work fine? Does the transmission operation return to normal once the fluid has cooled down but then go back into failsafe around 15 minutes after starting from cold? Does your transmission lock in 5th gear rather than 4th gear when failsafe is engaged, and also engage drive with a bit of a thump when selecting Drive from Neutral?
Phil
Post #486182 15th Aug 2018 2:39pm
Wickford90
Doesnt seem to be any other issues, suspension ok but will check tomorrow , no noise from drive to neutral, how would I check if it's stuck in 4th or 5th. Goes into fail safe after a couple of miles, will be normal again after a few hours parked.
I don't have a hand book so not sure if I can check oil levels from menu or have to do it manually.
Post #486239 15th Aug 2018 10:34pm
Wickford90
Reverse is fine, suspension goes up and down maybe a little slow and i can hear pump working
After a few minutes as I accelerated there was a thump then fail safe came on, neutral to drive I get a slight thump. Don’t know if it’s in 4 or 5 but at 50mph revs we’re at 2250, anything else I can do to help diagnose problem. Thanks
Post #486292 16th Aug 2018 3:06pm
RRPhil
I appreciate that, because the torque converter lock-up clutch is automatically disengaged in failsafe mode, it can be hard to distinguish between 4th and 5th gears just from the engine revs.
The reason this is important, though, is because it identifies if the fault lies with the transmission’s A-clutch. The transmission would normally failsafe into 4th gear (A & B clutches applied). The A-clutch is used in 1st, 2nd, 3rd & 4th gears so, if there is an issue with the A-clutch, the transmission has to failsafe into 5th gear instead (B & D clutches applied). The problem you are describing sounds exactly like a particular axial bearing has failed in your transmission, but this would cause the transmission to failsafe into 5th and not 4th.
4th is geared at 23.7mph/1000rpm and 5th at 29.5mph/1000rpm so, at 50mph, the input shaft turns at 2110rpm in 4th and in 5th at 1695rpm. Because of the slip across the converter (& the inaccuracy of the speedo) the engine speed won’t quite match these figures but you should be able to get close providing that you’re neither in a drive nor an overrun condition. You just need to get the throttle positioned so that the vehicle is coasting.
Phil
Post #486330 16th Aug 2018 10:07pm
Wickford90
Thanks will take it down the dual carriageway tomorrow and determine what is what. If the problem is as you suspect what would need to be done and ballpark cost, ( I appretiate cost is dependant on who does it)
Thanks for sharing your knowledge.
Post #486332 16th Aug 2018 10:52pm
RRPhil
If it’s the axial bearing/O-ring issue, and you’re handy with a set of spanners, then potentially you could repair it yourself quite cheaply, but with an element of risk. If you drop the transmission and only remove the A & B clutch assembly to replace the bearing and O-ring then the chances are that you’d get away with it with just £70 worth of parts.
The risk is that some of the individual needle rollers may have escaped and dropped into the sump and not have been caught by the four sump magnets.
If I were to do it, I would have to teardown the complete transmission so that I could put a warranty on it, and have the torque converter re-manufactured to ensure there was nothing in there that could re-contaminate the fluid. The total cost would be £1,650 incl. VAT, or £2,000 if you preferred a brand new torque converter. This includes 11 litres of LT71141 fluid, but not the cost of removing and refitting the transmission (which I don’t do).
I think if you shop around you’ll get quotes from anywhere between £1,200 and £2,500.
Anyway, hopefully it won’t come to that if it’s failing safe to 4th gear and we can narrow your issue down to something simpler (and cheaper!) to fix.
Phil
Post #486334 17th Aug 2018 12:14am
Wickford90
Thanks, going to take it for a run and try and confirm what gear it's stuck in.
Post #486352 17th Aug 2018 8:16am
Wickford90
Took it down long flat lane, at 1000rpm it hovered around 20 mph or a tad over, drove a few hundred mtrs and it was constant at that speed.
Post #486365 17th Aug 2018 10:47am
RRPhil
Unfortunately, the difference between engine speeds in 4th and 5th only becomes apparent at higher vehicle speeds. So, for example, at 60mph 4th gear is equivalent to around 2500rpm and 5th gear would be 2000rpm, so the 500rpm difference should be apparent on the rev counter.
As previously discussed, moving the throttle between drive and overrun, even at constant vehicle speed, will cause the engine speed to change significantly because the torque converter is unlocked, so finding the ‘coast’ condition where you are neither accelerating nor decelerating is a bit tricky.
Phil
Post #486373 17th Aug 2018 12:24pm
Wickford90
Thanks will take it out again later and check at 60mph, I guess there isn’t a sure fire way of checking.
Post #486374 17th Aug 2018 12:37pm
