Home > Technical (L322) > KEY 2007 programming
dingg1
has anyone ever managed to buy one of those chinese copy lookeylikey keys and manage to set it up using the gap iid tool?
if so could you point me to exact key that was purchased and programming guide
nb must be for 2007 car
I think the transponder chips change between vehicles and dates and that causes the no programme issue
Post #485440 8th Aug 2018 6:21am
dingg1
looking like no one has managed to do this then?
Post #486124 15th Aug 2018 12:32am
have you done a search? ... - .- -.
Post #486129 15th Aug 2018 6:15am
dingg1
Yes
Post #486180 15th Aug 2018 2:33pm
maybe search 'ebay keys'
http://www.fullfatrr.com/forum/topic41950....=ebay+keys ... - .- -.
Post #486183 15th Aug 2018 2:40pm
dingg1
done all the searches that are possible
hence the question and my comment re transponder changes , due to the fact we went from bmw to flip and then different security measures its a bit of a 'mare to find which transponder is fitted to a 2007 car , all the vendors will tell you 'yes it will work' until you end up with a load of keys that are only good for opening the door
sent a pm to daveo as he seems to know the situation
Post #486213 15th Aug 2018 6:32pm
dingg1
update
after a bit of info. from another forum member , it turns out the key sold to me as for my car is not the correct one , for info for 2007 facelift to 2009 we need the key with transponder pcf9741 id 46 , no other will work.
so time to buy another key with the correct gubbins inside and give that a go.
If that doesn't work I'm going to give up - maybe Rolling Eyes
Post #486344 17th Aug 2018 7:22am
clivehandforth
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
Agree with the transponder details, i purchased this one - https://www.ebay.co.uk/itm/292663432009 - which is the wrong blade but still correct transponder pcf9741 id46 although no luck and get the E07 error on the IID tool.
Have you managed to find another one that works yet?
Post #489120 17th Sep 2018 4:36pm
dingg1
No joy thus far
Have had correspondence with a guy in s africa who had programmed lots of keys to range rovers but never to a 2007- 2009 model using all sorts of key programmers.
I did send a pm to daveo as he appears to know the situation but he's dissappeared from here.
Be great to know if anyones ever cracked this
Post #489137 17th Sep 2018 6:03pm
dingg1
I got the e7 error too
Tried all versions of firmware on the iid tool , did get the new key to start the car on a couple of occasions but suspect the transponder doesnt hold the info and reverts back to unreadable from the car after key removal
Post #489138 17th Sep 2018 6:06pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I programmed an eBay key for my old D3 using the IID and it worked perfectly. The key was visually the same as the key for my new RR 2008 but I'm not sure about the transponder chip.
I'm keen to make a spare key for the RR so let us know if you find the right one.
Post #489147 17th Sep 2018 7:02pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
I have a 2007 with fixed key is that what you have as i have a spare chip
Post #489159 17th Sep 2018 8:13pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
the 2007-2009 keys are a pain, even if you got an ID46 chip it won't program with IID
I am able to supply any keys you need for any land rover feel free to PM for more details
Post #490986 4th Oct 2018 7:35pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
About time you turned up here Luke Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #490988 4th Oct 2018 7:40pm
