Home > Maintenance & Mods (L405) > Do I need an AirCon refrigerant change? |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Getting back to the OP, my experience was that the cooling on the drivers side of the car was not as effective as the passenger side. I have seen other threads on here stating the same issue when the Aircon is due a re-charge. I've just had mine done by Halfords using the newer gas (R1234YF) and both sides of the car are now ice cool £120. Reading online and trying to avoid the sales BS, it would appear the pipes used in car Aircon systems are very slightly porous, hence a gradual loss of gas over time. So advice would be, if it's working don't touch it and if it needs a re-gas, shop around the Interweb for the best price SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
4th Aug 2018 9:11am |
How would you know if it is not working Andy? |
4th Aug 2018 9:40am |
In my case, the recent hot weather highlighted that the drivers side would blow only moderately coldish air even when the 'max A/C' button was activated. SDV8 AB MY 2019
4th Aug 2018 9:48am |
Ours might be due a re-charge then. Everything seems a little slow. Thanks. |
4th Aug 2018 11:46am |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 |
Please guys, don't buy it, unless there is a problem the car ac shouldn't need a recharge.
4th Aug 2018 1:30pm |
A pleasure Ryan, I am cool and happy now! SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
4th Aug 2018 1:43pm |
4th Aug 2018 7:03pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1745 |
But the system is not 100% sealed, and gas leakage does occur, hence the need for a recharge... |
5th Aug 2018 6:33am |
Thats why i said unless some thing is wrong. Gas shouldn't leak out, the only point of exit is the shaft seal on the compressor. And that shouldn't leak either. All other components should be gas tight. There is no porus pipes etc, they may become porus after 15 to 20 years but not within the first few thats for sure.
5th Aug 2018 10:39am |
By law, the R134a systems can legally (and by design) lose upto 10% of its gas content
6th Aug 2018 9:49pm |
Flyingscotsman1 Member Since: 02 Mar 2021 Location: buckinghamshire Posts: 26 |
Had mine done on Monday at an approved L R shop they carried out all the L R tests and reported it all within L R tolerances but nowhere as cold as my old L355 |
24th Jun 2021 7:41pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1176 |
cheezels's posts on this thread about the drier are 100% correct.
24th Jun 2021 8:38pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
if that is all true why is it that a re-gas improves the 'coldness' of the AC.. ... - .- -.
24th Jun 2021 8:52pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Because you have lost some of the gas through the compressor seals.... |
24th Jun 2021 9:15pm |
