Home > Technical (L322) > Suspension fault
Dano0404
Suspension fault
Hello,
I have the bellow fault, anyone had this with any solution it’s been on the car for years now.
Thanks
free upload pictures
Post #484941 1st Aug 2018 9:02pm
if everything is working ok the dont worry about it.....i have re-occurring faults that when cleared they eventually come back but all my stuff works ok ... ... - .- -.
Post #484943 1st Aug 2018 9:15pm
Dano0404
Everything works just annoying having a suspension ding and a message every time I start it up.
Post #484944 1st Aug 2018 9:21pm
What car/year is your FFRR Dano? Please complete your profile.
The fault suggest a wiring problem to the reservoir valve, but not sufficient to cause a hard fault of the EAS system? (Rare... most often you just have to look at your FFRR the wrong way and it can hard fault Laughing
Might be worth having a look at the connections at the valve block
from RAVE:
Reservoir Valve
The reservoir valve controls the air pressure supply from the reservoir to the air springs. The
air suspension ECU (C0867) provides a feed to the valve block (C0771) on a UW wire, and
an earth path on a UG wire.
Post #484948 1st Aug 2018 9:58pm
Dano0404
Sorry it’s a 2007 sc. it’s running on lpg so the pump has been relocated and there is a possibility that the fault has been there since the conversion. Maybe caused by the conversion.
I did have a quick look tonight but I’ll look again tomorrow.
Thanks
Post #484953 1st Aug 2018 10:35pm
The reservoir valve is under the car, below the drivers seat
The ECU is tucked away behind the battery Evil or Very Mad
Post #484959 1st Aug 2018 11:10pm
Dano0404
Late update found the reservoir valve it's in the boot next to the pump. And had a broken wire going to it so connected it back up and all works fine. The lpg installer must have snapped it around 6 years ago. 2007 sc
Post #512737 21st Apr 2019 3:50pm
