![]() | Home > Maintenance & Mods (L322) > Reducing the access height even lower than the down setting |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
welcome to the forum..
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
The IIDTool allows custom heights to be set, no?
any height adjustments on the 2006 -2012 will be global greg...ie, adjust the access by -10mm and both the standard and offroad will go down by -10mm... ... - .- -.
I think there may be a way, though Stan, I set a super extended height and then mistakenly set that as NORMAL. I'll post a screen grab later..
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Gareth
Gareth-L Member Since: 01 Aug 2018 Location: Glossop Posts: 4 ![]() ![]() ![]() |
Thanks for the kind welcome Richard.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
What about something like this:
Joking apart I have considered ramps but there are so many technical issues it is a non starter on top of the angle needing to be almost vertical! |
From my quick search I would have preferred to find a folding ramp with a level platform which could go along side the car, and would fit "fold flat" in the boot.
madpugger Member Since: 07 Feb 2013 Location: Aberdeenshire Posts: 49 ![]() ![]() |
I wish I could tell you how to do this exactly, but unfortunately I can't! However, there WILL be a way to do this, after all, the suspension is controlled by a computer, which is programmed by a human... We just need to find the right human to re-write the software!
Thank you so much for your comprehensive response. That really does give me food for thought.
You're very welcome.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2660 ![]() ![]() |
I produce the LLAMS plug-in kit that provides lowered and raised height adjustments depending on a switch setting which can lower the L322 and others to the bump-stops. I provide it at a very low price when used for mobility-impaired people. Please PM me for details if interested.
Interesting,
