![]() | Home > In Car Electronics (L322) > Random Alarm Activation |
Kiwimac Member Since: 15 Jun 2018 Location: Wellington Posts: 48 ![]() ![]() ![]() |
I've had random alarm activity once a day since I bought the car home.
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 ![]() ![]() ![]() |
Agreed. Mine did it every time the sun came out.
Ah. That could well be it. I did think to myself that it seemed to be about the same time of day - so maybe it is when the sun comes over the house and onto the front of the car!
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Yup ours had just rubbed on the paintwork of the bonnet by the smallest amount, then when the bonnet heated up it must have just lifted that extra bit and the alarm was triggered. We touched up the tiny tub mark, put some 2mm rubber over top to ensure it has a decent amount of pressure on it and it’s been great in the 2 years since. |
Likewise the paint is rubbed on mine.
Went off at 0925 today, so I think it must be a sun issue.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
its a common problem.
If I pull the plug block out, will the system then complain incessantly that the switch is not connected, or just remain silent and ignore the switch? |
Doesn't complain on mine, I believe the default is an open circuit, but when the button lifts it closes the circuit and send the signal, so when disconnected, car believes bonnet is closed. .
Yeah it’s normally open so car believes all is well |
The car was in the shop the other day (faulty rear washer) and I had them disconnect the bonnet switch whilst they were at it.
Can anyone identify the correct part number? I have found at least two!
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3869 ![]() ![]() ![]() |
I currently have the bonnet switch unplugged - it causes no problems and of course has the added benefit of the alarm not going of when the sun shines. On my previous RR I did stick a thin rubber foot on the underside of the bonnet which also solved the alarm problem, I would do that again but I can't find a suitable bit of rubber - or foot |
Probably easiest to email Dan at site sponsor Duckworth Parts with your VIN and model etc, and he'll be able to sort the part. ![]() |
