Home > Wheels & Tyres > Pictures of an L322 with BFG all terrains?
04fullfatman
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
Hi all
Buying new rubber soon and want to fit BFG all terrains, but Im struggling to find any pictures of an L322 with 18" BFG all terrains fitted. Does anyone have these fitted, and can you share your experience / pictures with these? Seems to be an unpopular choice!
I can find some threads talking about the various sizes that will fit - and its seems like 265/65/18 will fit without modification and rubbing. Can anyone confirm this?
Thanks
Post #484046 22nd Jul 2018 12:29pm
Classic888
Hi. What model and year is your RR? 04 by any chance. If you have Brembo brakes (not standard on a 2004) fitted you will only be able to use 19" and above wheels. Use a tyre size comparison site to check the technical spec of your existing tires against the size you are thinking of putting on. A lot of the cars technical bits are fed by the wheel speed sensors.
Post #484058 22nd Jul 2018 4:49pm
Vogue
TD6 came as Standard with 18” up to 2006 - if it’s the original calipers it will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #484060 22nd Jul 2018 5:25pm
Classic888
So everyday is a school (learning) day. After three years as a member I have just found out how to see what model a forum member has. Bow down Thumbs Up Thanks Vogue.
Post #484062 22nd Jul 2018 5:56pm
Vogue
Thumbs Up Very Happy 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #484064 22nd Jul 2018 6:17pm
GraemeS
I have LT275/55R20 BFG AT KO2 on mine. Initially the noise wasn't too bad but now they resonate in the otherwise very quiet cabin even though I've applied damping material on every flat panel that I can find behind guard liners, on the channels underneath and in the rear. I yearn for them to wear out. Perhaps a smaller size might not be so bad.
Post #484081 22nd Jul 2018 9:27pm
04fullfatman
Thanks, have you any pictures of tyres on the truck?
Post #484195 23rd Jul 2018 10:02pm
GraemeS
Post #484200 24th Jul 2018 1:38am
