![]() | Home > Wheels & Tyres > Pictures of an L322 with BFG all terrains? |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
Hi. What model and year is your RR? 04 by any chance. If you have Brembo brakes (not standard on a 2004) fitted you will only be able to use 19" and above wheels. Use a tyre size comparison site to check the technical spec of your existing tires against the size you are thinking of putting on. A lot of the cars technical bits are fed by the wheel speed sensors. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
TD6 came as Standard with 18” up to 2006 - if it’s the original calipers it will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
So everyday is a school (learning) day. After three years as a member I have just found out how to see what model a forum member has. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2577 ![]() ![]() ![]() |
I have LT275/55R20 BFG AT KO2 on mine. Initially the noise wasn't too bad but now they resonate in the otherwise very quiet cabin even though I've applied damping material on every flat panel that I can find behind guard liners, on the channels underneath and in the rear. I yearn for them to wear out. Perhaps a smaller size might not be so bad. |
04fullfatman Member Since: 12 Jul 2018 Location: Dublin Posts: 5 ![]() ![]() ![]() |
Thanks, have you any pictures of tyres on the truck? |
