Home > Technical (L322) > 2002 TD6 Vogue Battery and starting issues
Lefty
South Africa 2002 Range Rover Vogue Td6 Zambezi Silver
Neutral Hi all.
I needed to disconnect my battery today and on reconnecting it, an alarm sounds and the engine will not start. the lights come on and all the rest but the engine is dead.
I have noticed that the interior lighting and gear selector lights do not illuminate, neither does the Immobilizer LED flash.
I have tried a hard reset of the ECU but no use. I suspect the immobilizer.
Please help!!
Post #484056 22nd Jul 2018 4:25pm
Check your battery connections and battery condition - suggest put on charge Thumbs Up .
Post #484069 22nd Jul 2018 7:04pm
holidaychicken
Can you plug it into diagnostics ?
I used to lose sync between the EWS module and Engine ECU on my 4.4 which needed to be reprogrammed using testbook or faultmate or similar. This happened if I disconnected the battery. You would have a fault logged in the immobiliser system.
Post #484089 22nd Jul 2018 11:01pm
Lefty
Hi, the diagnostic does not work either. all the interior lights, immobilizer led and diagnostic are dead it would seem.
I checked the immobilizer fuses but they were OK, could it be others?
Post #484101 23rd Jul 2018 6:44am
holidaychicken
Reference Joe90's post above, what voltage does your battery have, can you try jump starting from another vehicle and check battery connections?
If you look in rave there are fuses behind the glove box and in the ECU box under the bonnet but battery condition would be the first thing to check.
Post #484102 23rd Jul 2018 7:24am
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Have you tried disconecting battery to reset ?
Post #484108 23rd Jul 2018 7:57am
Lefty
Hooray, progress!! Checked Battery -OK, then went through fuse box and found 2 blown diagnostic fuses.
We are up and running again. Thanks Chaps!
Now, anyone know anything about changing out a Gearbox ECU?
Post #484112 23rd Jul 2018 8:09am
What is wrong with it?
(Do you mean the gearbox or transfer box ecu ?) .
Post #484154 23rd Jul 2018 2:07pm
Lefty
I have recently bought the vehicle. the seller told me that it needed to be replaced and sent it with.
He said it is plug and play and to me the process seems pretty straight forward but.....I have learned the hard way that such things are seldom as straight forward as they seem, so just checking.
Post #484158 23rd Jul 2018 2:47pm
Question
Are you getting gearbox problems / fault messages / limp mode?
Suggest some diagnostics to identify the problem... .
Post #484274 24th Jul 2018 10:00pm
Lefty
Hi Yes I am.
I have a Hawk eye and a Fault finder FCR. any suggestions which one is better?
I put my battery on charge for the past 2 days and it seems to have rectified the problem i.e it is starting now, but there are all sorts of warning lights (ABS, EtC etc) glowing now as well as the messages you mentioned.
Post #484286 25th Jul 2018 7:15am
Have you done a steering wheel lock to lock, these tend to clear the "Christmas tree" effect after a battery disconnection? .
Post #484320 25th Jul 2018 4:30pm
Lefty
Done so but think I need to check those fuses as well.
Post #484347 26th Jul 2018 6:46am
