![]() | Home > Technical (L322) > Rubbing noise front right |
WeeJ Member Since: 12 Aug 2012 Location: Aberdeen Posts: 29 ![]() ![]() |
When I turn left at medium speed I get a rubbing noise. Its a kind of shuch shuch shuch tpye noise but I cant see anything rubbing or loose. `Any ideas? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
Brake shield? |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Either of the above or loose heatshield around front prop? |
Big Mac Member Since: 24 Jul 2018 Location: North West Posts: 3 ![]() ![]() ![]() |
Hi there I have the same issue, recently the cars had new discs and pads and new replacement suspension bags all around (just to rule them out) did you ever get to the bottom of this ?
Paulus1978 Member Since: 09 Nov 2017 Location: Leicester Posts: 89 ![]() ![]() ![]() |
I'd expect some noise from the pads and discs as the two new faces bed in. It should go after a few hundred miles of gentle bedding in driving. Don't stamp on the brakes to bed them in faster, you'll only warp the disc and need new ones again. |
Hi I’ve done around 1200 miles since the disc and pads were replaced, the noise was there before and afterwards. Also the noise doesn’t happen when the cars cold, only after it’s warmed up |
My next suspect would be a wheel bearing then. I'm assuming based on what You've said the noise doesnt go away under breaking? |
Hi there no the noise doesn’t go away under braking and only there on the up take from say 5mph to 30 mph before the engine noise possibly drowns it out (no noise when slowing down), could it be the diff as when the vehicles been stood and cold the noise isn’t there for the first mile or so |
