![]() | Home > Technical (L322) > Hub nut removal |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
or take your hubs off again... HAHA...will try to avoid that.
Ha Ha a wee bit, rest assured , battery disconnected !
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I would stitch weld it and remove the two brackets to make it look nice and neat. Paintable seam sealer similar to the link below would finish it off if you haven't welded it fully.
Hmm after welding the brackets on and painting them , and all the cut marks , o everything was not to bad, I thought about stitching but it looked quite neat as it is and strong . So shoes on and new spring and pins to backing plate and discs back on . |
Good job |
Hmm not a good job yet Ok , having completed the replacement of the rear abs rings on my L322 I still have a fault with the system . HDC and suspension inactive , I have below these faults yet again , it’s not that I haven’t seen them before but my only thought is that I will have to deal with the front rings , how can I conclude this theory please , should I get readings from the wiring at the abs ecu while ignition on , I may add that all four sensors have been replaced , but in the initial replacement the old ring has grazed the sensor face . Maybe measure the sensor face left ? Just a bit stuck in this long
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
What rings have you replaced?
The gap tool never seems to give a code , I find it sometimes quite random, The rings I have replaced are both the rears , you can see this back in the thread, The left rear appeared first then dissappeared as the speedometer indicated , but the signals were not good and as it turns out they were both gone completely. I can bring up a pic of the last three faults remaining , as per Gap tool , I will connect my other diagnostic to ascertain any faults. |
OK , the first three are the result of the last pic I downloaded, I then went into diferent diagnostic tool and got these after a run , to my surprise both rear sensors which are new albeit slightly scraped from the old rings are coming up including the can bus , which is well , not getting the right message to sync with the abs ecu. The Gap tool remains with the original faults. Mt question therefore having a specific tool for that model , why in hell does it not pick up yjr sensors , why would I need two diagnostics .....Arghh Can I assume I have damaged both new sensors? Apoligise for the upload but cant see rear left pic , it is there . I just struggle a bit with computers lol.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Don't see an ABS fault code... |
The Contisys Scan has picked up abs fault though?
What brand of sensors? |
Rimmers , I think I know what your going to say though. I reckon I’ll try and temporary swap front to rears they were new also, it might prove that I damaged the rears on the old rings . I ain’t paying £100 a pop ! |
Not had anybody luck with aftermarket ones. I’ll only fit OEM/Genuine now... |
