Home > Technical (L322) > AIR SUSPENSION RIDE HEIGHT CONTROL WHEN TOWING |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2487 |
Automatic height changes that normally occur with some TR settings are disabled as well as high speed lowering but manual height changes remain available. |
14th Jul 2018 10:55pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1370 |
I've not tried on mine. But its got a trailer attached at the moment, so will try it in the morning. Mine is an aftermarket towbar with the electric kit, and the trailer light illuminates on the dash when connected.
14th Jul 2018 10:56pm |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
Mine 100% lets me alter it, I always raise it to offroad to lower the jockey wheel and then lower to uncouple and the reverse for coupling. I also had to drop it yesterday while on the move so that I could get the ariel under the height restriction at my local tip Current
15th Jul 2018 8:38am |
westminster 62 Member Since: 03 Oct 2017 Location: essex Posts: 20 |
Going by your replies seems like mine is how it should be, what made me doubt it was the fact that the hand book says you can't alter the height when connected,
15th Jul 2018 6:49pm |
The warning in the towing section should begin with "automatic" which is implied further in the paragraph but is initially misleading. The trailer blinker indication only when using the genuine wiring is also incorrect because it has nothing to do with the wiring, instead only if incandescent globes or LED lights with load resistors equivalent to incandescent globes are used on the trailer. |
15th Jul 2018 8:51pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 749 |
Had mine changed from twin to 13! Job done by the main dealer, like you I was looking for it perform as in the handbook!
16th Jul 2018 7:20pm |
