Home > Technical (L322) > AIR SUSPENSION RIDE HEIGHT CONTROL WHEN TOWING
westminster 62
United Kingdom 2012 Range Rover Westminster TDV8 Santorini Black
Hi everybody, when i connect my caravan plug to my car everything works apart from the ride height control, according to the handbook when the caravan is connected to the car (13pin plug) suspension height changes are disabled when land rover approved socket is in use, this isn't happening on mine i can still raise the car to off road height with everything connected, spoke to the main dealer and they say according to land rover i should be able to alter the ride height when caravan is connected but i'm not convinced, i used to own a 2004 RR with the same type of tow-bar and when i connected the caravan the ride height was locked at normal height and the padlock symbol would light up orange while the car was towing caravan.
Has anybody come across this? i would have thought the hand book was correct.i would be grateful for any help.
my car is 2012 westminster 4.4td
Post #483462 14th Jul 2018 10:28pm
GraemeS
Automatic height changes that normally occur with some TR settings are disabled as well as high speed lowering but manual height changes remain available.
Post #483463 14th Jul 2018 10:55pm
fisha
I've not tried on mine. But its got a trailer attached at the moment, so will try it in the morning. Mine is an aftermarket towbar with the electric kit, and the trailer light illuminates on the dash when connected.
I remember on my 2002 one, that the selection of ride height between normal and highway mode would lock out when a trailer was attached, but that option doesn't exist anymore on my '08. V8 or else ...
Post #483464 14th Jul 2018 10:56pm
andygts
Mine 100% lets me alter it, I always raise it to offroad to lower the jockey wheel and then lower to uncouple and the reverse for coupling. I also had to drop it yesterday while on the move so that I could get the ariel under the height restriction at my local tip Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #483469 15th Jul 2018 8:38am
westminster 62
Going by your replies seems like mine is how it should be, what made me doubt it was the fact that the hand book says you can't alter the height when connected,
Thanks everybody.
Post #483523 15th Jul 2018 6:49pm
GraemeS
The warning in the towing section should begin with "automatic" which is implied further in the paragraph but is initially misleading. The trailer blinker indication only when using the genuine wiring is also incorrect because it has nothing to do with the wiring, instead only if incandescent globes or LED lights with load resistors equivalent to incandescent globes are used on the trailer.
Post #483532 15th Jul 2018 8:51pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Had mine changed from twin to 13! Job done by the main dealer, like you I was looking for it perform as in the handbook!
Doesn’t happen, my rear fog lights still come on when connected! They shouldn’t ! 2014 vogue se
Post #483597 16th Jul 2018 7:20pm
