Home > Technical (L322) > PDC Module - Need Help
dan_uk_1984
Can I send someone my PDC module to test pls?
Needs to be 2002-2004 I think? With front and rear sensors. You'll need to be happy gaining access to your module to swap the plugs over. It lives in the right hand side of the boot, behind the fuse board, so three nuts need undoing.
My fronts still dont work, but all wiring seems to be intact.
You can just seen one of the plugs (blue) here:
18112010200 by d86cfv, on Flickr
Post #41243 6th Dec 2010 11:10pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
have not been near the electrics on a range rover yet so give me a basic guide and ill do it,
Or if you ever travel to london anytime you can do the test yourself on mine, im on the east side.
have front and rear sensors, 2004. 2004 black Vogue TD6
Post #41247 6th Dec 2010 11:23pm
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Dan, you can use mine if you like when I come over for the electrics? Is it the same ..... mine only being a lowly HSE an' all?? Whistle
Post #41250 6th Dec 2010 11:30pm
daveo
hi dan, send it to me ...no probs V8 facelift Range Rover Autobiography 22" wheels.
Post #41251 6th Dec 2010 11:31pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
doesn't matter which MY as it is the same from BMW through to Facelift models. I'll test it if you want to drive up to Lyneham...
I also still have my old one here if you want to use that to fault find. Also have a couple of new sensors in the garage that you may want/need to buy! I can give you a hand with the diagnostics of it if you want as well...
Just let me know
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #41258 7th Dec 2010 12:11am
daveo
hi dan, sounds like stevegt is your man.. Thumbs Up well done steve V8 facelift Range Rover Autobiography 22" wheels.
Post #41273 7th Dec 2010 8:12am
dan_uk_1984
Thanks for the offers guys, I guess it would make sense to pike your brains Steve - I'll drop you a PM.
James - Are you around this weekend?
Dave - Have you got photo's of the trims yet?
D
Post #41278 7th Dec 2010 9:24am
Dolphinboy
Dan i am here on Saturday adn early Sunday am (til 12)
Post #41310 7th Dec 2010 1:05pm
dan_uk_1984
Dolphinboy wrote:
Dan i am here on Saturday and early Sunday am (til 12)
Cool, might treck over to yours on Sat late afternoon then if thats any good?
Post #41316 7th Dec 2010 1:30pm
Dolphinboy
Sat sounds ace! will chill the beers! Or should that be defrost??
Post #41321 7th Dec 2010 2:02pm
dan_uk_1984
Just an update to close this off. I bought a random BMW PDC ECU because it "looked right" turns out it works fine and I now have fully functioning PDC.
It cost all of £27 inc P&P from fleabay
Described as:
Compatible BMW Part #'s
P/N: 66216921414
P/N: 66216942676
P/N: 66216958515
P/N: 66216985500
P/N: 66219112454
P/N: 66209129816
From the E83 and E53 (X3 & X5)
Faulty LR PDC ECU:
Range Rover PDC ECU by d86cfv, on Flickr
Working BMW PDC ECU:
BMW PDC ECU (fits Range Rover) by d86cfv, on Flickr
Post #44533 4th Jan 2011 6:13pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Did the backs work and just the fronts not. Non of mine work and i have one wire that i knows not connected on the front due to me stripping wire but they never have worked since i got it. would one wire stop whole system, Might take a gamble on this unit (mines 2002) Look ok?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
I have no clicking from any sensors at all?
Post #48327 31st Jan 2011 8:58pm
dan_uk_1984
You can have my old module if you want - only the rears worked with it. If you want to just test it?
D
Post #48333 31st Jan 2011 9:49pm
Nickj
Going to wire the broken sensor wire back up tomorrow and go from there i think. May take you up on that though Dan. Thumbs Up
Post #48423 1st Feb 2011 8:53pm
