Home > Technical (L322) > PDC Module - Need Help |
Can I send someone my PDC module to test pls?
6th Dec 2010 11:10pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3162 |
Dan, you can use mine if you like when I come over for the electrics? Is it the same ..... mine only being a lowly HSE an' all?? |
6th Dec 2010 11:30pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi dan, send it to me ...no probs V8 facelift Range Rover Autobiography 22" wheels.
6th Dec 2010 11:31pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
doesn't matter which MY as it is the same from BMW through to Facelift models. I'll test it if you want to drive up to Lyneham...
7th Dec 2010 12:11am |
hi dan, sounds like stevegt is your man.. well done steve V8 facelift Range Rover Autobiography 22" wheels.
7th Dec 2010 8:12am |
Thanks for the offers guys, I guess it would make sense to pike your brains Steve - I'll drop you a PM.
7th Dec 2010 9:24am |
Dan i am here on Saturday adn early Sunday am (til 12) |
7th Dec 2010 1:05pm |
Cool, might treck over to yours on Sat late afternoon then if thats any good? |
7th Dec 2010 1:30pm |
Sat sounds ace! will chill the beers! Or should that be defrost?? |
7th Dec 2010 2:02pm |
Just an update to close this off. I bought a random BMW PDC ECU because it "looked right" turns out it works fine and I now have fully functioning PDC.
4th Jan 2011 6:13pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
Did the backs work and just the fronts not. Non of mine work and i have one wire that i knows not connected on the front due to me stripping wire but they never have worked since i got it. would one wire stop whole system, Might take a gamble on this unit (mines 2002) Look ok?
31st Jan 2011 8:58pm |
You can have my old module if you want - only the rears worked with it. If you want to just test it?
31st Jan 2011 9:49pm |
Going to wire the broken sensor wire back up tomorrow and go from there i think. May take you up on that though Dan. |
1st Feb 2011 8:53pm |
