Home > Technical (L322) > Automatic lights |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi - I'm no expert but there should be two sensors behind your mirror I believe. 1 for rain sensor and the other for light. Not sure which way round they are. If it's the sensor then they are about £35 I believe to replace as I enquired about upgrading recently.
19th Jan 2011 8:49pm |
As comports says - but to avoid confusion its not in the mirror housing, those sensors are for the dim dip. It's kinda under the mirror "foot" mounted to the screen. When you look at it from outside it looks red and shiny.
19th Jan 2011 8:52pm |
Hackweg Member Since: 06 Oct 2010 Location: Medway Posts: 22 |
don’t know if a replacement screen has been fitted but I don’t think so, so the sensor is the black block glued to the windscreen if this needs changing then I guess as I have seen in some other postings you can buy one from the dealer test it in the car park and see if it works if not return it. My one question is how do you remove it from the windscreen and what do you use to re-attach it |
19th Jan 2011 9:19pm |
I believe that info is in the WiKi |
19th Jan 2011 10:02pm |
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 |
good luck to you !!
20th Jan 2011 11:06am |
Perhaps try a different dealer? One that knows what they are doing? |
20th Jan 2011 11:12am |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 382 |
I am having same problem and the question is how do you remove the plastic cowling to get to the sensor. The dealer told me that the rain and light sensor are one unit. Thx!Mike |
22nd Jan 2011 5:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
you've asked this same question on the RRS forum and got an answer so why ask again here.... |
22nd Jan 2011 6:21pm |
Wow, it's like I didn't actually post that at all. Maybe a link will spoon-feed it right on in there: http://www.fullfatrr.com/wiki/Main_Page |
22nd Jan 2011 7:15pm |
Been to the dealer (had to order a sensor as they are not a stock item)
31st Jan 2011 1:11pm |
did you dis-connect the battery when you did the sensor job, if no then try that...
31st Jan 2011 1:30pm |
had the same problem... see my other reply....
31st Jan 2011 1:50pm |
Thanks the wiper sensor does not seem to work either but unsure how the automatic bit works. Mine work when I turn them on but seem to work like ordinary intermittent wipers that are adjusted using the delay control time control and not dependant on water being present.
31st Jan 2011 7:34pm |
I just replaced the auto light/rain sensor (they are combined into one module) and still the lights do not come on after dark in the auto position. I replaced the fuse as well. I noticed Scary said to disconnect the battery. I did not do this. Can I/should I do it after I already installed it? Mike |
2nd Feb 2011 12:34am |
