![]() | Home > Technical (L322) > Automatic lights |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
Hi - I'm no expert but there should be two sensors behind your mirror I believe. 1 for rain sensor and the other for light. Not sure which way round they are. If it's the sensor then they are about £35 I believe to replace as I enquired about upgrading recently.
As comports says - but to avoid confusion its not in the mirror housing, those sensors are for the dim dip. It's kinda under the mirror "foot" mounted to the screen. When you look at it from outside it looks red and shiny.
Hackweg Member Since: 06 Oct 2010 Location: Medway Posts: 22 ![]() ![]() ![]() |
don’t know if a replacement screen has been fitted but I don’t think so, so the sensor is the black block glued to the windscreen if this needs changing then I guess as I have seen in some other postings you can buy one from the dealer test it in the car park and see if it works if not return it. My one question is how do you remove it from the windscreen and what do you use to re-attach it |
I believe that info is in the WiKi |
iancollins Member Since: 17 Mar 2010 Location: milton keynes Posts: 264 ![]() ![]() ![]() |
good luck to you !!
Perhaps try a different dealer? One that knows what they are doing? ![]() |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
I am having same problem and the question is how do you remove the plastic cowling to get to the sensor. The dealer told me that the rain and light sensor are one unit. Thx!Mike |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
you've asked this same question on the RRS forum and got an answer so why ask again here.... ![]() |
Wow, it's like I didn't actually post that at all. Maybe a link will spoon-feed it right on in there: http://www.fullfatrr.com/wiki/Main_Page ![]() |
Been to the dealer (had to order a sensor as they are not a stock item)
did you dis-connect the battery when you did the sensor job, if no then try that...
had the same problem... see my other reply....
Thanks the wiper sensor does not seem to work either but unsure how the automatic bit works. Mine work when I turn them on but seem to work like ordinary intermittent wipers that are adjusted using the delay control time control and not dependant on water being present.
I just replaced the auto light/rain sensor (they are combined into one module) and still the lights do not come on after dark in the auto position. I replaced the fuse as well. I noticed Scary said to disconnect the battery. I did not do this. Can I/should I |
