Home > General > Fog Light HID Upgrade |
Has anyone used an HID kit to upgrade their fog lights?
30th Jan 2011 12:44pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Do the HID upgrade, they are far superior, and second best wont cut it............. Ian |
30th Jan 2011 12:58pm |
I'm guessing you know you can get fined for using them in certain cases as they are only to be used in adverse weather ........... Law RVLR regs 25 & 27
30th Jan 2011 1:37pm |
hongkongphooey Member Since: 26 Aug 2010 Location: Douglas. Posts: 227 |
HID.
30th Jan 2011 1:58pm |
However - one can use them as driving lights when used in conjunction with main beam. Although technically I think they have to be wired to only come on with main beam... I wouldnt drive through a town with them on, I want them for the increased visability... |
30th Jan 2011 3:15pm |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 |
You could change them to LED foglight bulbs to give brighter whiter light and probably about a tenner? |
30th Jan 2011 5:38pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
led's wont give the forward beam that dan wants nick...i've experimented with leds in my fogs and i finally decide to put them in my main beam and use them as drl's, very bright as you look at them but as i said no forward beam. ... - .- -.
30th Jan 2011 6:04pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I'm getting a feeling we have been hear too many times but any hoo ,
30th Jan 2011 6:31pm |
agree with AXLE , after market hids need 'projector' type housings ..
30th Jan 2011 6:56pm |
OK, from reading up on it online and from what you guys have said - HID is not the way to go. Wrong beam pattern etc.
30th Jan 2011 9:04pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I'm ashamed to say, when I was a nipper, I had 80w/100w H4 headlight bulbs in the Mini, they had the blue glass on the bulbs, they were a really bright white, wrecked the headlights due to the extra heat and almost set fire to the wiring due to the extra current.
30th Jan 2011 9:16pm |
So if it has the cap it's fine?
30th Jan 2011 9:24pm |
Its similar to the standard fog light bulb. In as much that the tip is coated so that the light is thrown to the reflector and not just anywhere. Ian |
30th Jan 2011 9:28pm |
Sorry to piggy back this thread but if i use LEd fogs (2002 l322) (main reason being i have a set that fit into the 2010 fog unit) will i need to use resistors to prevent dash error message. I'm guessing the answers yes as per evry led upgrade!! |
3rd Feb 2011 9:58pm |
