Home > In Car Electronics (L322) > ULF 54 PIN ADAPTER LOOM REQUIRED
Shambler
Sorry to raise the subject of Bluetooth again 😱 but can anyone help point me in the direction of where I can purchase one of the fabled ulf wiring adapter looms please? Yes I know I could swap out the pins etc but I’d rather keep things standard if you know what I mean, just in case lol plus it may already have a pairing button fitted πŸ‘πŸ»πŸ˜œ
Post #482453 2nd Jul 2018 8:37pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Shambler, you can't keep it 'standard' if you're fitting a ULF !!!
The BMW ULF module uses different pin outs to the stock RR unit, so if you buy the RR loom you have to change the pins.
Folk can make a loom for you or you can make one yourself
I managed to buy a complete rear loom, with RR pinning, took the bits out I wanted and re-pinned
The problem was my loom had been smashed somewhere around the rear passenger door area, that just gave me a microphone cabling issue Wink
Post #482471 3rd Jul 2018 6:47am
Shambler
Ahh ok I thought there was a plug in adapter someone had made, I seem to recal seeing it mentioned on a post somewhere πŸ€”
Post #482532 3rd Jul 2018 7:13pm
mjdronfield
I think it sells for like stupid pounds.
I did mine myself after buying a new plug from an Audi dealer, and just moved the pins I needed across. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #482540 3rd Jul 2018 8:17pm
Bushy30
Shambler,
I can't be far from you, happily do it for you if you have the bits
Bushy
Post #482544 3rd Jul 2018 8:52pm
Fact is, there isn't anything else you can plug in to the 54 pin plug, so repinning for the ULF only adds value...especially if there is a ULF module attached to it!! Thumbs Up
My pdf for repinning
http://www.fullfatrr.com/gallery/albums/us...0Chart.pdf .
Post #482549 3rd Jul 2018 9:14pm
Shambler
Where abouts are you Bushy? May take you up on that offer, We’re near Cheltenham πŸ‘
Post #482584 4th Jul 2018 8:13am
Bushy30
pretty close then Chipping Norton Smile
Post #482590 4th Jul 2018 8:50am
Shambler
Cool, not far away, when would be good for you to have a look πŸ‘
Post #482592 4th Jul 2018 8:53am
p38arover
Australia
I bought an empty plug to do that too. The empty plugs cost a bomb here in Oz. If anyone wants one here in Oz, I want to sell mine. Changing the pins on the original plug is quite easy. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #482607 4th Jul 2018 12:23pm
Bushy30
Shambler,
Just sent you a PM
Bushy
Post #482635 4th Jul 2018 4:36pm
