Home > Maintenance & Mods (L322) > First of many questions
Northern lad
Hi All
My first question, as my Newbie intro states, and hopefully I’ve put it in the right category. Below is a list of advisories on the last MOT (please ignore the tyre comments, the last owner had kerbed three of the wheels, I don’t think any concerning damage has been done to the rubber) the oil leak is absolutely minimal, the handbrake however is a joke! It points to the roof lining when fully applied, and just about holds her on tick over in D
just wanted an idea of the likely costs I can expect, to repair the other items, MOT is in January, I’m guessing at about £500-600 at the garage, I can’t do a lot of things myself any more, knackered knees and all that stuff
Any ideas greatly appreciated
Many thanks
Steve
• Nearside Front tyre cuts on sidewall not down to cords soon
• Nearside Front Brake pipe slightly corroded ends soon (3.6.B.2c)
• Nearside Front Lower Suspension arm rubber mounting deteriorated but not resulting in excessive movement inner bush cracking up (2.4.G.2)
• Nearside Front Suspension arm rubber mounting deteriorated but not resulting in excessive movement back arm bush starting to split (2.4.G.2)
• Offside Front tyre small cuts on sidewall not down to cords soon
• Offside Rear tyre small cuts on sidewalls not down to cords soon
• Oil leak ()
• handbrake high
Post #482243 30th Jun 2018 8:49am
Please fill in your profile so we know what car you have got!
Looks like both front and rear suspension bushes will all need doing soon
Possibly new handbrake cable, new brake shoes and new rear discs and back plates
If one of your brake pipes is corroded, recommend removing all the inner wheelarch on the RHS and the covers front to back, quite likely all is rusty and needs replacing
Oil leak ?
Tyres ?
Hopefully you have £2K set aside for all this....( a year) Thumbs Up .
Post #482244 30th Jun 2018 9:09am
Northern lad
Thanks Joe for a quick response
2K! Big Cry welcome to the world of RR ownership
incidentally I did fill out the car details in my profile, not sure why they don't appear, i'll put some info in my signature instead, so thanks for the heads up.
just a few pics (not the best i'm afraid)
 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #482246 30th Jun 2018 9:32am
very smart Thumbs Up
unless you have service / repair history that says otherwise, seriously check out your brake pipes, especially the long run front to back .
Post #482250 30th Jun 2018 9:39am
Northern lad
thanks again
Sorry I should have thought about including the items she failed on, and since repaired to pass MOT
Drivers airbag obviously defective (5.4.1)
Offside Front Exhaust has a major leak of exhaust gases (7.1.2)
Nearside Rear brake caliper securing device missing clip missing (3.5.1j)
Nearside Rear Brake pipe excessively corroded on top of wishbone arm (3.6.B.2c)
Offside Rear Brake pipe excessively corroded top of wishbone arm (3.6.B.2c)
Offside Front Brake pipe excessively corroded up under cover (3.6.B.2c) 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #482255 30th Jun 2018 9:57am
Dolphinboy
Your offside exhaust leak will be a crack in the front edge of the cat where the manifold comes down from the engine and enters the catalyst. Well known fault but can be welded for c. £50
Handbrakes can be adjusted by most mechs at a garage (c. £50 but there is a wiki here) but If it has run out of adjustment play then things get difficult and expensive
Post #482276 30th Jun 2018 4:43pm
Northern lad
dolphinboy
can you give me more detail please, why is it more difficult if the cable has run out of slck 2003 Vogue 4.4 petrol, silver 126k on clock when I got her
Post #482288 30th Jun 2018 8:13pm
Dolphinboy
NOt an expert in this but know from others they have had probs getting bits off etc. due to age and corrosion.
http://www.fullfatrr.com/forum/topic531.html
http://www.fullfatrr.com/wiki/Handbrake_cable_replacement
Post #482297 30th Jun 2018 10:33pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
Oil leak is probably the valve cover gaskets - common problem, replacement seals are about £30 but get them replaced by an independent specialist - could also be the PCV valve causing pressure and forcing oil under the seal.
Post #482333 1st Jul 2018 12:23pm
