Home > Technical (L322) > Height sensor according to IID tool |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
So I’ve finally worked out what sensor is playing up. For weeks I got “articulation relay fault” which didn’t really tell me anything. Now, I’m getting “front left height sensor”
28th Jun 2018 7:08pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Try swapping sensor to the other side |
28th Jun 2018 7:40pm |
They’re handed though aren’t they? |
29th Jun 2018 7:52am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 517 |
There is a procedure for testing the sensors in the workshop manual. Essentially put 5V across the sensor and measure the output. There should be a fairly linear change in output from about 4.5V down to 0.5V across the range -140mm to +180mm.
29th Jun 2018 8:05am |
Relevant pins for the front left sensor are (if I'm reading the diagram right)
29th Jun 2018 3:59pm |
So only three pins in use then. I’ll have a look at it and see if there’s anything obvious |
29th Jun 2018 10:19pm |
I’ve found a break in one of the wires to the sensor. I’ve soldered it and the fault cleared. However, when I drove it, the suspension went skywards at the front again. However, no errors on the dash and IID can’t find any faults. It’s getting on my nerves now
4th Jul 2018 8:06am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
The venting exhaust on the compressor can block up.. the car keeping rising can be a sign of this if It can’t vent |
5th Jul 2018 2:08pm |
What do the live values for the height sensors look like? And same goes for the gallery pressure. If it's not venting you may be able to see it in the live values. 2016 Skoda Octavia VRS Estate <gone>2009 FF Vogue TDV8 Buckingham Blue</gone> <gone>2015 BMW 520D SE (not my favourite car)</gone> <gone>2009 D3 HSE Galway Green</gone> |
5th Jul 2018 4:18pm |
Ive had some fun and games with it today. First of all I checked the valves in the “test valves” section and all four corner seems to rise and fall but the n/s/R air suspension wouldn’t inflate after a while. At first I thought it was that causing the issues so I jacked the car up to help it a little and I heard the compressor start running. I then got it to a sensible height and turned off the ignition. A few minutes later with the car off and locked, the front end had risen up to past off road height again!
5th Jul 2018 8:51pm |
