Home > Technical (L405) > Dancing headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
if you have AFS headlights, the ones that follow the road as you go round corners , then thats perfectly normal..the headlights are adjusting them selves.... ... - .- -.
24th Jun 2018 4:17pm |
Don Henshall Member Since: 25 Sep 2010 Location: Essex Posts: 114 |
Thanks Stan but it’s the signature light that are dancing about? Happens whilst reversing as well as moving forward. Very strange.... 718 GT4
24th Jun 2018 4:26pm |
those drl/signiture lights should be fixed..do you mean they are loose in the headlight unit? ... - .- -.
24th Jun 2018 4:29pm |
No not loose in the headlight they are flashing/ dancing.
24th Jun 2018 4:36pm |
upload your video to youtube and place the link here.. ... - .- -.
24th Jun 2018 4:39pm |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
If you video it they will look like they are flashing and moving around and that is perfectly normal as LED lights flash but very quickly so the human eye can't see it. When you video them the frame rate of the camera, unless perfectly timed to the lights will show them as flashing. Now you may have a problem with the lights but videoing them probably wont show it up! Cheers Ian
24th Jun 2018 4:45pm |
You can see it with the naked eye. Will post a link soon.
24th Jun 2018 4:47pm |
&feature=youtu.be
24th Jun 2018 4:59pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
That doesn't look normal , maybe the controller that dims them when an indicator is on is playing up. 2015 4.4 AB
24th Jun 2018 5:07pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
Mine does that if filmed with an iphone 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
24th Jun 2018 5:16pm |
If you can see it with the naked eye then yes there is a problem and you should take it in to have the garage look at it
24th Jun 2018 5:17pm |
Thanks anyway.
24th Jun 2018 5:29pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
Was they previous owner a rapper? |
24th Jun 2018 6:46pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
It looks like each lamp has two elements which make up the whole signature look, each element in each light appears to be flashing alternately, not normal at all.
24th Jun 2018 6:51pm |
