![]() | Home > Technical (L405) > L405 Engine Blown - 2013 Model Less than 50K miles on clock |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
You may have seen this http://www.fullfatrr.com/forum/topic45832....ne+failure
waqaveli Member Since: 17 Jun 2018 Location: Reading Posts: 6 ![]() ![]() ![]() |
So I’ve just received a video link of a technician walking under the car and pointing to a hole in the engine that is behind the starter motor and saying this is where the “internals of the engine have come through” and “a new engine is required”.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
This has just got out of hand.
Cheers Red Merle for the great insightful and constructive response |
You're welcome. |
Bill Member Since: 18 Nov 2017 Location: Essex / Normandy Posts: 1279 ![]() ![]() |
Is that me Red? ![]() If so... I’m of the view, the manufacturers liability for faulty manufacture /design and the dealer retains responsibility& is almost without limit (6 years) regardless of warranty or not. Some of the other links showed this fault back in 2014???? So the dealer should know when sold. Check I’m working from memory... not so good nowadays. I should also ask if the car was serviced tween buying at28k and 48k miles However I’m also of the view legal action is a pain in the backside and really not worth the candle. Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc He who dies with the most toys wins... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I think 40% from LR is a generous offer.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Just my pennies worth, the wrong oil is a big thing and proof of this is essential. I disagree with others that an engine of 48k should not be covered under a general liability but I'm not familiar with the law. Obviously if the engine was modified or altered from standard or serviced incorrectly then that's completely different. I have a customer who get a new E class every 4 years which means he has one year without cover. A timing chain snapped 6 months out of warranty on the second to last one and Merc ireland replaced the engine as a sign of goodwill. This took one call and they couldn't do enough for him. We are talking about a conrod letting go at 48k, not an alternator or a turbo issue.
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Can anyone who's not posted or has posted maybe just put themselves in the shoes of a person without a car that on the fair side, shouldn't have gone pop.....and then ask would they like to stump up 10k. I think you'd all say no, so I get the warranty not being there but I think we'd all like some recourse from a body that probably has bigger pockets than ours. all smug in my new plug!
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569 ![]() ![]() ![]() |
Personal opinion: This would be pretty straightforward for any company seriously interested in customer service. Here we have a 5 year old car with only 48k miles on it and FSH. The engine has suffered a catastrophic failure, which clearly it shouldn't have. It has nothing to do with legal responsibilities, quite simply LR should be all over this not only paying for the repair in full, but carrying out a comprehensive investigation to find out what went wrong so that they can prevent it happening again. Oh, hang on, of course, LR know full well what went wrong, it's happened on numerous occasions before with this engine type, hence why they are trying to run away from their crystal clear moral obligations.
A warranty doesn't cover normal wear & tear - so I guess by definition only covers failures that shouldn't have happened......
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
RVBush......an excellent and balanced summary, and very true.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
To my mind this case is different from the other reported cases of spun bearings or broken crank as none of the reports that I have read refer to there being a hole in the engine casing where a part, presumable a conrod, has come through. So I am not sure that it is safe to conclude that the failure was a common one or related to a design fault. It might be, but unless the engine is dismantled nobody knows for sure, and for the reasons given above there is not much benefit in the owner paying for the dismantling. I would accept the offer of a 40% contribution and put it down to bad luck. |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
RVBush, well said.
