Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 3 of 15 <123 4 ... 131415>
GraemeS
A new sensor will require calibration mode to be set. My IIDTool needed a special version to set calibration mode but the option may have since been incorporated into a general release.
Post #480922 14th Jun 2018 8:50pm
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
I am sure I will this either get done by the friendly local dealer or with the help of GAPs team. Mr. Green
We will see how it develops and I will report back.
But thanks for th hint! Truly appreciated because such things can stop you from finalising these things.
regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #480971 15th Jun 2018 1:55pm
heppsen
here we go, parts 1 and 2 - bracket and wiring loom are inbound at the local friendly.
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #481323 19th Jun 2018 4:17am
GraemeS
I couldn't see anywhere in this thread where I mentioned that the radar unit needs a 10A fuse fitted to the engine bay junction box E17 slot. The graphic on the lid diagram will be recognised. Fitting the radar unit c/w fuse without re-configuring the CCF from CC to ACC will cause faults due to the unrecognised canbus messages so best to leave the fuse out until ready to change the CCF.
Post #481332 19th Jun 2018 7:14am
heppsen
many thanks for this great info - surely safes a lot of nerves once done Laughing
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #481505 21st Jun 2018 6:03am
Nick Evans
Got mine all fitted & working but have not fitted a fuse yet ! Graeme can you confirm if your horn button works on the new switch because mine doesn’t thinking this maybe linked to the missing fuse ? My horn works fine on the right hand switch & with the original left hand switch but not the new acc switch.
Post #481745 24th Jun 2018 12:02pm
GraemeS
I'll confirm later when my wife isn't asleep but the wiring schematic shows that the fuse is solely for the radar unit. Hence I suspect that the electrical connector for the switch isn't fully home.
Is the new switch the same colour as the old one? The early version of the switch requires both switches to be replaced if changing one to the later switch. I understood that this was purely due to a change in switch colours so that the colours matched rather than any functional / electrical change but perhaps the change of colours was to distinguish the different sets of switches.
Has the CCF been changed yet to activate ACC? However I couldn't imagine that this would affect the horn button function.
Update: Yes, the horn works from the new ACC switch bank.
From Microcat, LR029644 switch, LH, when used to replace earlier levels, must be fitted in pairs.
This suggests not just a change in colour.
Post #481800 24th Jun 2018 8:42pm
GraemeS
Later switches started at vin BA349700 according to Microcat.
RH matching switch is LR029647.
Post #481806 24th Jun 2018 11:09pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Graeme,
There are a couple of hints in here about Queue Assist and Start/Stop -- I have ACC already, can I make this do QA and SS simply by changing things with my IID tool?
Thanks Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #487996 4th Sep 2018 4:29pm
GraemeS
Yes, QA/SS are just CCF parameters that can be set using the IIDTool.
Post #488027 4th Sep 2018 8:58pm
Bushy30
Thanks Graeme, play time tomorrow then Very Happy
But you say this wasn't standard in the UK? So to be careful trying it? Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #488029 4th Sep 2018 9:09pm
GraemeS
Simply reiterating warnings from others (GAP & BBS IIRC), which is a reasonable approach considering that LR reportedly didn't make this feature available on the L322 but possibly over-cautious if the feature was available on the first L405.
Post #488030 4th Sep 2018 9:35pm
kooky_guy
I've been wondering about enabling this too. I'd be interested to see how it goes! 2010 4.4 TDV8 Vogue SE
Post #488032 4th Sep 2018 9:40pm
GGDR
What? Hidden features we can just turn on?
Queue Assist I googled and sounds nice!
Start/Stop? All google revealed was engine start/stop, it's not this is it?
. Cheers, Greg
Post #488041 5th Sep 2018 6:11am
GraemeS
Start/stop in this context is the same as queue assist whereby the vehicle can be brought to a stop then resume ACC on touching the throttle but perhaps the CC resume button. The couple of times that I cautiously allowed the vehicle to be stopped to test the feature, I didn't subsequently resume ACC.
Post #488045 5th Sep 2018 7:39am
