Home > Orders (L405) > PHEV delivery dates - info sought
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 4 of 4 <1234
Rob99
I suspect the next major FF model (L5xx ??) will be designed as an electric vehicle with any compromise being for the petrol/diesel versions, which will likely be phased out during the following few years. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #480685 11th Jun 2018 1:30pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Thanks for those pictures of the boot. Not great but not the end of the world either.
Eirik34 wrote:
The raised floor together with the executive rear seats gives less cargo space.
The key question is wether LR will design the next ff with batteries in mind in the platform itself, so that the next phev ff RR can get the same cargo space as the petrol/diesel versions, and so that the phev versions could get electrical deployable tow bar and side steps as well?
The executive seats are a delete option - you can spec the normal ones
Deployable sidesteps are now on the configurator (or I am pretty sure they were the last time I tried)
Not sure about the tow bar.
Post #481138 17th Jun 2018 9:21am
What are the lower 2 buttons on the right side of the boot ?
That’s where my deployable towbar buttons are.
Any idea of the real life range ?
That’s the main concern I have - can you just keep going on petrol only ?
Post #481142 17th Jun 2018 10:18am
ilard
Interesting to hear from an actual owner, of course, but from I can see on the rest of the internet most people can expect a solid 20 miles EV-only range. Of course you can run in combo mode, which is the default setting, and if the battery runs out of juice then you can plod along on petrol-only. From our friends here and from P400e reviews I am increasingly reassured by the petrol engine which is described as tourqy and surprisingly refined (quiet, anyway) unless you are ragging it.
Those two buttons should be the rear suspension height adjust. If you had a deployable tow bar the buttons would be to the right of these. Above these buttons are the electric seat folding options, left side and right side controlled separately.
Post #481178 17th Jun 2018 3:35pm
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
One thing I'm curious about - most new orders seem to specify the panoramic glass roof - couldn't that huge area of glass be converted into a solar panel to help with charging? Just a thought, but the FFRR seems the ideal vehicle to carry such a panel.
Post #489208 18th Sep 2018 11:56am
This topic is locked: you cannot edit posts or make replies.  Back to top
Page 4 of 4 <1234
