Home > In Car Electronics (L322) > Bluetooth ULF upgrade again -- sorry for another thread
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Hi Folks,
4.4V8 04 plate
Doing some prep work for adding ULF -- I've found the white X400 -- but it's plugged into a harness that goes to a nokia box in the front passenger footwell -- no problem to disconnect.
I don't currently have a 54pin connector, and intend to make my own loom when I get bits -- but I'm struggling with microphone at the moment -- I've found these: -
Are they what I'm looking for, and if so, how to connect, also if someone has the direct pin info for the loom I need to make I'd be very thankful.
Here's hoping Smile
Post #480608 10th Jun 2018 4:29pm
This thread may help, look for posts with pdf links (e.g. last post)
http://www.fullfatrr.com/forum/topic35589....p;start=15 .
Post #480613 10th Jun 2018 5:21pm
Bushy30
Thanks Joe, I actually have the same connect2 box, I was hoping just to dosconnect the loom, but maybe use the front to back connections for the microphone?
Thanks for the pointer to the PDF
Post #480615 10th Jun 2018 5:31pm
Bushy30
Further -- thanks to Joe for the pins on the 54 pin plug, anyone know which does what in the the 12 pin X400?
Post #480617 10th Jun 2018 5:38pm
IIRC the 12 pin connector serves no function with regards to the ULF module .
Post #480624 10th Jun 2018 6:31pm
Bushy30
Now thats really confused me -- I thought I was creating a loom from a 'new' 54pin on the ULF to the 12 pin X400, have I got that wrong? If I have it'll be right back to the start as I have no other connectors Sad
So I guess the real question is -- where do the wires go out of the 54pin?
Thanks
Post #480634 10th Jun 2018 7:11pm
My last post was easy to say given I am pre-wired for the 54 pin Twisted Evil
See here:
http://www.fullfatrr.com/forum/topic27721....ulf+54+pin
but also do some forum searches on "54 pin" and "ulf", lots of info on here .
Post #480637 10th Jun 2018 7:30pm
Bushy30
Thanks Joe -- that'll be what I'm trying to do, trouble is Jamie didn't finish telling us how he did it Wink
Post #480641 10th Jun 2018 7:55pm
Bushy30
OK, according to the wiring diagram, the Black/Yellow/black in the roof is indeed microphone pos/neg/sheild -- now, where is the other end of that ???
Post #480651 10th Jun 2018 10:21pm
Bushy30
news......... used a cable tone to trace to the centre console for the mic lead -- I might just use the old connect2 front to back cabling and the old nokia mic instead of all this faffing...........
Post #480732 12th Jun 2018 12:11am
