![]() | Home > Maintenance & Mods (L322) > Wheel Nuts |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Hi , plenty of solid ones ( with no caps ) available on ebay. Use the search function on here and you will see a long post about them. I have them in mine and they are very good. 2015 4.4 AB
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
strange I couldnt find it on search.
Hi , bought mine a while ago but just had a quick look and aaw these,
Thanks mate.. these are similar to the OEM ones so no point getting them. I have found a swollen nuts thread which is referring to solid wheel nuts that also has an ebay link but its not working.
Sorry , i thought that link was for the solids. My bad 2015 4.4 AB
ok so found the solid ones [url]Look at this on eBay http://www.ebay.co.uk/itm/111810992021[/url]
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 895 ![]() ![]() ![]() |
If you Google Wrington Engineering they have very nice stainless steel nuts for pre & post 2005 wheels, although relatively pricey at £220 for 20 |
I believe they are the ones i have on mine. 2015 4.4 AB
cheers JCW, guess 220 is a bit steep lol.. although they would be ideal. Current:
The ebay ones you posted are the ones i have. 2015 4.4 AB
sweet.. might go with them as £40 is not too bad Current:
hi folks, the solid wheel nut seem to be out of stock on fleabay just now
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 ![]() ![]() ![]() |
You could try the 12 point universal sockets that grip on the corners of the nut, these can be used on a lot damaged nuts and still grip enough to hold. David Please let me know if my comments upset you, I may wish to upset you again. |
Cheers David.. I got the nuts off with the 23mm socket..
