Home > Maintenance & Mods (L322) > Wheel Nuts
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Wheel Nuts
Hi folks,
Has anyone else tried to use different wheel nuts? Due to the bad design, the bolt rusts under the aluminium cover and a 22mm socket no longer fits.. I have even struggled with a 23mm and 24mm is too loose.
On a few wheel nuts, I had sheer the aluminium cover off to take the nut off.
Wondering if there are some replacement nuts Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #449330 28th Aug 2017 2:38pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi , plenty of solid ones ( with no caps ) available on ebay. Use the search function on here and you will see a long post about them. I have them in mine and they are very good. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449334 28th Aug 2017 2:56pm
scotcruz
strange I couldnt find it on search.
any ebay item numbers mate? Current:
Past:
Post #449335 28th Aug 2017 2:57pm
dolph34
Hi , bought mine a while ago but just had a quick look and aaw these,
eBay Item No. 121763463590
Make sure they fit yours before buying. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449338 28th Aug 2017 3:08pm
scotcruz
Thanks mate.. these are similar to the OEM ones so no point getting them. I have found a swollen nuts thread which is referring to solid wheel nuts that also has an ebay link but its not working.
Wondering what size are they. Current:
Past:
Post #449340 28th Aug 2017 3:10pm
dolph34
Sorry , i thought that link was for the solids. My bad 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449341 28th Aug 2017 3:11pm
scotcruz
ok so found the solid ones [url]Look at this on eBay http://www.ebay.co.uk/itm/111810992021[/url]
Wondering if anyone has used them? as hoping the colour doesnt fade. Current:
Past:
Post #449344 28th Aug 2017 3:21pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
If you Google Wrington Engineering they have very nice stainless steel nuts for pre & post 2005 wheels, although relatively pricey at £220 for 20 Shocked
Post #449345 28th Aug 2017 3:25pm
dolph34
I believe they are the ones i have on mine. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449348 28th Aug 2017 3:43pm
scotcruz
cheers JCW, guess 220 is a bit steep lol.. although they would be ideal. Current:
Past:
Post #449357 28th Aug 2017 5:39pm
dolph34
The ebay ones you posted are the ones i have. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #449358 28th Aug 2017 5:40pm
scotcruz
sweet.. might go with them as £40 is not too bad Current:
Past:
Post #449359 28th Aug 2017 5:42pm
scotcruz
hi folks, the solid wheel nut seem to be out of stock on fleabay just now
can anyone recommend a shop where I could buy them? Current:
Past:
Post #480369 7th Jun 2018 5:03pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Re: Wheel Nuts
scotcruz wrote:
Hi folks,
You could try the 12 point universal sockets that grip on the corners of the nut, these can be used on a lot damaged nuts and still grip enough to hold. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #480375 7th Jun 2018 7:30pm
scotcruz
Cheers David.. I got the nuts off with the 23mm socket..
Just want to replace them with the solid wheel nuts but cant seem to find them on Fleabay, just the normal ones which after a while will be the same. Current:
Past:
Post #480391 7th Jun 2018 11:40pm
