Home > Technical (L322) > Thermostat |
Deltaevo Member Since: 02 Apr 2017 Location: Ashbourne Posts: 39 |
Did mine a few days ago with the 88 degree stat, mine has a blanking plug where the sensor would go. No issues running without the sensor. |
15th May 2018 7:47pm |
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 |
Have read issues surrounding excessive heat due to 105 degree thermostat fitted to 4.4 engine, have just ordered
16th May 2018 8:45am |
I bought this stat
16th May 2018 3:46pm |
M17tph Member Since: 09 Apr 2017 Location: Crawley Posts: 51 |
Thanks for the replys
16th May 2018 4:10pm |
Much quieter, and the pipes around the rad are no longer rock hard. I needed my stat changing anyway so it would be a positve thing to do in my view. |
17th May 2018 8:56am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1526 |
Re rock hard hoses, what is the pressure rating on the coolant reservoir tank, 140 or 200kPa (look at the number underneath the cap)? Ron B. VK2OTC
17th May 2018 11:16am |
Caps rated at 200. |
23rd May 2018 5:06pm |
I'd suggest changing to 140 kPa p/n PCD000070
How many coolant reservoirs and radiators has your L322 gone through? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
24th May 2018 8:50am |
None under my tenure. A year of ownership. |
24th May 2018 2:41pm |
140 kPa = 20 psi
25th May 2018 4:55am |
