Home > Wheels & Tyres > Wheel nuts for different alloys Guide
Page 4 of 4 <1234
Danwilderspin
Also I only found this thread recently I currently have stormers with the original lugs :-/ seem to fit / torque ok is it a lot more thread? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468961 16th Feb 2018 11:59pm
Danwilderspin
To make matters more confusing I thought I’d see which size they sell to go with their wheels... they sell both!
Is there a way to tell if they will be any good if I remove one or anything before getting a whole wheel off? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #468963 17th Feb 2018 12:39am
Dan, both the RR nuts look alike but the later silver ones have a larger diameter shank... If you need the silver nuts and fit the smaller black nuts then you run the risk the wheel will twist on the nuts and loosen itself...
Post #468965 17th Feb 2018 2:09am
Provarmint
England 2007 Range Rover SE TDV8 Buckingham Blue
Can somebody point out why I can't get a 22mm socket on the wheel bolts, it's a 2007 L322. 22mm too small, 23mm too loose,??????
Thanks in advance.
Post #479194 23rd May 2018 1:54pm
they might be swollen....the FF's nuts are prone to this.. ... - .- -.
Post #479198 23rd May 2018 2:31pm
Provarmint
Swollen???? What is the solution.
Post #479203 23rd May 2018 2:48pm
force a 22mm socket onto the swollen nut, undo and replace with new... ... - .- -.
Post #479204 23rd May 2018 2:53pm
Provarmint
Any idea on price for a set?
Post #479205 23rd May 2018 3:03pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
You can a set of "new take offs" where someone has changed from eg chrome to black for about £45 off ebay.
Dan at Duckworths may also have a set or 2 Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #479208 23rd May 2018 3:57pm
Dizzy Dee
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Just got a full set of 20 for £38.50 from Fleabay.
Post #479374 25th May 2018 8:59pm
Page 4 of 4 <1234
